Aller au contenu principal
Wahl Lithium Ion 5537C Blade Replacement
Ce dont vous avez besoin
  1. Wahl Lithium Ion 5537C Blade Replacement, Shaver Blade: étape 1, image 1 de 2 Wahl Lithium Ion 5537C Blade Replacement, Shaver Blade: étape 1, image 2 de 2
    • Take out the batteries by pulling off the cover from the back and once done put the cover back on.
  2. Wahl Lithium Ion 5537C Blade Replacement: étape 2, image 1 de 3 Wahl Lithium Ion 5537C Blade Replacement: étape 2, image 2 de 3 Wahl Lithium Ion 5537C Blade Replacement: étape 2, image 3 de 3
    • Using the Phillips #0 screwdriver, remove the two screws on the blade and place them in the container.
    • Detach the blade from the body of the shaver and also remove the blade supporting mounts.
  3. Wahl Lithium Ion 5537C Blade Replacement: étape 3, image 1 de 3 Wahl Lithium Ion 5537C Blade Replacement: étape 3, image 2 de 3 Wahl Lithium Ion 5537C Blade Replacement: étape 3, image 3 de 3
    • Grab the replacement new blade and before mounting the support mount clean it with the cleaning brush to remove any dirt.
    • Place the supporting mount back to the new blade making sure it is properly attached.
  4. Wahl Lithium Ion 5537C Blade Replacement: étape 4, image 1 de 3 Wahl Lithium Ion 5537C Blade Replacement: étape 4, image 2 de 3 Wahl Lithium Ion 5537C Blade Replacement: étape 4, image 3 de 3
    • Place the blade with mount attached to the trimmer such that the screw holes are visible through
    • Grab on the blade hard and torque both screws one by one.
    • Check if the blade is attached tightly to the trimmer.
    • Insert the batteries inside the trimmer and start using!
Osman Saeed
Membre depuis le 07/11/21
109 Réputation
1 tutoriel rédigé
Équipe
York University, Team S1-G9, Allen Summer 2021 Membre de l'équipe York University, Team S1-G9, Allen Summer 2021
YORK-ALLEN-SU21S1G9
1 membre
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 19
30 derniers jours : 78
Total : 1,549
