Introduction
Use this guide to replace the power switch on your device.
Pièces
Aucune pièce nécessaire.
Unscrew the 12 mm Phillips head screws located at the top of the cover and at the bottom two corners, using a Phillips #1 Screwdriver.
  • Unscrew the 12 mm Phillips head screws located at the top of the cover and at the bottom two corners, using a Phillips #1 Screwdriver.
Ajouter un commentaire
Unscrew the two black 5.556 mm Phillip head screw on the power switch with a Phillips #0 Screwdriver.
  • Unscrew the two black 5.556 mm Phillip head screw on the power switch with a Phillips #0 Screwdriver.
  • Shimmy the power switch off the mount until it is completely removed.
Sophia Swearengin
Membre depuis le 26/09/2017
542 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S14-G5, Boczar Fall 2017 Membre de l'équipe USF Tampa, Team S14-G5, Boczar Fall 2017
USFT-BOCZAR-F17S14G5
2 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 8
Total : 57
