Aller au contenu principal
Wand Company Star Trek Communicator Silver Plate Replacement
Ce dont vous avez besoin
  1. Wand Company Star Trek Communicator Silver Plate Replacement, Silver Plate: étape 1, image 1 de 1
    • Power off the Star trek Bluetooth Communicator before disassembling.
  2. Wand Company Star Trek Communicator Silver Plate Replacement: étape 2, image 1 de 2 Wand Company Star Trek Communicator Silver Plate Replacement: étape 2, image 2 de 2
    • Remove the four T6 Torx screws (1.70mm) located on the back of the device.
    • Remove the black plastic cover by gently pulling it.
  3. Wand Company Star Trek Communicator Silver Plate Replacement: étape 3, image 1 de 2 Wand Company Star Trek Communicator Silver Plate Replacement: étape 3, image 2 de 2
    • Remove the protective foam located around the speaker and charging magnets.
    • Be careful not to lose the two magnets located between the microphone and the speaker. The magnets can be easily removed if they come in contact with other magnetic materials.
  4. Wand Company Star Trek Communicator Silver Plate Replacement: étape 4, image 1 de 1
    • Remove the two Phillips PH0 (0.9mm) screws located to the side of each magnet.
  5. Wand Company Star Trek Communicator Silver Plate Replacement: étape 5, image 1 de 1
    • Remove the black cover.
  6. Wand Company Star Trek Communicator Silver Plate Replacement: étape 6, image 1 de 1
    • Remove the protective foam attached to the battery.
  7. Wand Company Star Trek Communicator Silver Plate Replacement: étape 7, image 1 de 2 Wand Company Star Trek Communicator Silver Plate Replacement: étape 7, image 2 de 2
    • Remove the five Phillips PH0 (0.9mm) screws located at the top and bottom of the silver plate.
  8. Wand Company Star Trek Communicator Silver Plate Replacement: étape 8, image 1 de 1
    • Remove the silver plate.
2 autres ont terminé cette réparation.
Garret Moses
Membre depuis le 02/15/17
313 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 5-6, Passmore Spring 2017 Membre de l'équipe USF Tampa, Team 5-6, Passmore Spring 2017
USFT-PASSMORE-S17S5G6
4 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 9
Total : 556
