Aller au contenu principal
Waring 51BL29 Motor Replacement
Ce dont vous avez besoin
  1. Waring 51BL29 Motor Replacement, Bottom Panel: étape 1, image 1 de 2 Waring 51BL29 Motor Replacement, Bottom Panel: étape 1, image 2 de 2
    • Turn the blender on its side so the bottom panel is facing you.
    • Unscrew the 22mm Phillips #1 screw on the indent of the panel.
    • Unscrew the 3 screws in the rubber holes.
  2. Waring 51BL29 Motor Replacement: étape 2, image 1 de 1
    • Remove the bottom panel.
  3. Waring 51BL29 Motor Replacement, Drive Coupling: étape 3, image 1 de 1
    • Place the screwdriver in the head of the middle flat-head screw.
  4. Waring 51BL29 Motor Replacement: étape 4, image 1 de 1
    • Unscrew this screw while holding the coupling with your other hand and not allowing it to rotate.
    • This screw may be reverse-threaded.
  5. Waring 51BL29 Motor Replacement: étape 5, image 1 de 1
    • Once the coupling mechanism has been loosened all the way, gently pull it off the top of the blender.
  6. Waring 51BL29 Motor Replacement, Motor: étape 6, image 1 de 2 Waring 51BL29 Motor Replacement, Motor: étape 6, image 2 de 2
    • Unscrew the four nuts in the bottom of the motor cavity.
    • Wiggle the motor until it is free and you can remove it.
  7. Waring 51BL29 Motor Replacement: étape 7, image 1 de 1
    • Once motor is pulled out, unscrew the 8 mm screw for the green wire from the base of the blender.
  8. Waring 51BL29 Motor Replacement: étape 8, image 1 de 3 Waring 51BL29 Motor Replacement: étape 8, image 2 de 3 Waring 51BL29 Motor Replacement: étape 8, image 3 de 3
    • Unscrew each white wire cap in order to free the motor from the power cord.
    • Once wire caps are removed, separate wires carefully.
Dean Becker
Membre depuis le 04/17/17
470 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team S15-G4, Banghart Spring 2017 Membre de l'équipe Cal Poly, Team S15-G4, Banghart Spring 2017
CPSU-BANGHART-S17S15G4
4 membres
5 tutoriels rédigés
Un commentaire
Hi
Where do I source a replacement motor? I have been looking without success for UK supplier. Thanks Jill
I have a much loved Vintage Waring blender …
Jill Lancaster - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 10
30 derniers jours : 31
Total : 2,534
