Aller au contenu principal
Waring Pro SB30 Hot Plate Replacement
Ce dont vous avez besoin
  1. Waring Pro SB30 Hot Plate Replacement, Back Panel: étape 1, image 1 de 1
    • Remove the screws on the back panel with the #1 Phillips screwdriver bit.
    • The screws in the rubber legs of the burner do not need to be removed.
    • If the back panel has never been opened before, the screws may be more difficult to unscrew.
  2. Waring Pro SB30 Hot Plate Replacement: étape 2, image 1 de 2 Waring Pro SB30 Hot Plate Replacement: étape 2, image 2 de 2
    • Using a wrench, remove the bolt from the center of the back panel.
  3. Waring Pro SB30 Hot Plate Replacement: étape 3, image 1 de 1
    • The back panel can now be easily lifted off.
  4. Waring Pro SB30 Hot Plate Replacement, Hot Plate: étape 4, image 1 de 2 Waring Pro SB30 Hot Plate Replacement, Hot Plate: étape 4, image 2 de 2
    • Remove screws #1 Phillips screwdriver bit.
    • The interior edges of the metal frame are sharp and can cause minor cuts.
    • 3 screws on the perimeter of the circle
    • 1 screw in the circle
    • 2 screws on the eletrical stands with wires
  5. Waring Pro SB30 Hot Plate Replacement: étape 5, image 1 de 2 Waring Pro SB30 Hot Plate Replacement: étape 5, image 2 de 2
    • Remove rod from the center of the plate with a wrench.
  6. Waring Pro SB30 Hot Plate Replacement: étape 6, image 1 de 2 Waring Pro SB30 Hot Plate Replacement: étape 6, image 2 de 2
    • Remove plate carefully as to not damage internal components i.e. insulator, metal frame, wires, etc.
2 autres ont terminé cette réparation.
Sun Fai Lau
Membre depuis le 09/22/14
588 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 10-7, Brown Fall 2014 Membre de l'équipe USF Tampa, Team 10-7, Brown Fall 2014
USFT-BROWN-F14S10G7
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 10
Total : 1,932
