Aller au contenu principal
Waring Pro SB30 Indicator Lights Replacement
Ce dont vous avez besoin
  1. Waring Pro SB30 Indicator Lights Replacement, Back Panel: étape 1, image 1 de 1
    • Remove the screws on the back panel with the #1 Phillips screwdriver bit.
    • The screws in the rubber legs of the burner do not need to be removed.
    • If the back panel has never been opened before, the screws may be more difficult to unscrew.
  2. Waring Pro SB30 Indicator Lights Replacement: étape 2, image 1 de 2 Waring Pro SB30 Indicator Lights Replacement: étape 2, image 2 de 2
    • Using a wrench, remove the bolt from the center of the back panel.
  3. Waring Pro SB30 Indicator Lights Replacement: étape 3, image 1 de 1
    • The back panel can now be easily lifted off.
  4. Waring Pro SB30 Indicator Lights Replacement, Indicator Lights: étape 4, image 1 de 1
    • Using two thin screwdrivers (or similar objects) wedge them into the slots of the plastic shell of the desired light.
  5. Waring Pro SB30 Indicator Lights Replacement: étape 5, image 1 de 2 Waring Pro SB30 Indicator Lights Replacement: étape 5, image 2 de 2
    • Push the screwdrivers inward and guide the bulb outwards.
    • Gently grab by the wires and remove bulb from plastic shell.
Sun Fai Lau
Membre depuis le 09/22/14
588 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 10-7, Brown Fall 2014 Membre de l'équipe USF Tampa, Team 10-7, Brown Fall 2014
USFT-BROWN-F14S10G7
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 289
