Introduction
The plastic sides can become damaged, melted or warped when using a pot larger than the burner. So be sure to remove the back panel first before pulling these sides off.
The screws are located along the interior sides of the metal frame, so consider wearing gloves when removing the screws to avoid cuts from the sharp edges.
Ce dont vous avez besoin
Remove the screws on the back panel with the #1 Phillips screwdriver bit.
The screws in the rubber legs of the burner do not need to be removed.
Using a #1 Phillips screwdriver bit or a ratchet wrench with a Phillips screwdriver bit to remove screws located on the interior frame.
