Aller au contenu principal
WarioWare: Twisted! Rumble Motor Replacement
Ce dont vous avez besoin
  1. WarioWare: Twisted! Rumble Motor Replacement, Rumble Motor: étape 1, image 1 de 2 WarioWare: Twisted! Rumble Motor Replacement, Rumble Motor: étape 1, image 2 de 2
    • Use a Tri-point Y0 screwdriver to remove the single 3 mm screw located at the back of the game.
    • Remove the cover to expose the control module electronics board underneath.
  2. WarioWare: Twisted! Rumble Motor Replacement: étape 2, image 1 de 3 WarioWare: Twisted! Rumble Motor Replacement: étape 2, image 2 de 3 WarioWare: Twisted! Rumble Motor Replacement: étape 2, image 3 de 3
    • Heat up the soldering iron to approximately 350 degrees Fahrenheit.
    • Remove the rumble motor from the slot.
    • For more information on soldering, refer to How to Solder and Desolder Connections.
    • Apply the tip of the soldering iron to the connection points, causing the red and blue wires to melt and detach.
    • Separate the old rumble motor from the board and set it aside.
    • The soldering iron will be very hot. Do not touch the tip of the iron. It will cause severe burns.
  3. WarioWare: Twisted! Rumble Motor Replacement: étape 3, image 1 de 3 WarioWare: Twisted! Rumble Motor Replacement: étape 3, image 2 de 3 WarioWare: Twisted! Rumble Motor Replacement: étape 3, image 3 de 3
    • Use your hands to remove the black sleeve from the old rumble motor.
    • Set the old rumble motor aside.
    • Use your hands to place the black sleeve onto the new rumble motor you're using.
  4. WarioWare: Twisted! Rumble Motor Replacement: étape 4, image 1 de 3 WarioWare: Twisted! Rumble Motor Replacement: étape 4, image 2 de 3 WarioWare: Twisted! Rumble Motor Replacement: étape 4, image 3 de 3
    • Place the red wire onto the plus (left) side, and the blue wire onto the minus (right) side.
    • To reattach the red and blue wires, carefully bring the tip of the soldering iron into contact with the connection points.
    • The soldering iron will be hot. Do not touch the tip of the iron.
    • Place the new rumble motor back in its slot.
    • Turn off the soldering iron after you finish this step.
  5. WarioWare: Twisted! Rumble Motor Replacement: étape 5, image 1 de 3 WarioWare: Twisted! Rumble Motor Replacement: étape 5, image 2 de 3 WarioWare: Twisted! Rumble Motor Replacement: étape 5, image 3 de 3
    • Put the cover back on the game.
    • Gently push the two sides back together.
  6. WarioWare: Twisted! Rumble Motor Replacement: étape 6, image 1 de 2 WarioWare: Twisted! Rumble Motor Replacement: étape 6, image 2 de 2
    • Use your Tri-point Y0 screwdriver to screw the single 3 mm screw back into place.
    • Test the game to make sure the problem is fixed and you should be ready to play!
I hope this guide solved your problem, and your game should work like new again!
Brent Thompson
Membre depuis le 06/21/23
133 Réputation
1 tutoriel rédigé
Équipe
Un commentaire
Nice post and please provide more information. Thanks for sharing.
cunez - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 57
Total : 1,351
