Introduction
This is a general instruction for an audience with limited mechanical skills, to replace the line in a generic bump head weed whacker. Before beginning this guide turn off the machine.
Remove cutting line guard from weed whacker. This is usually attached by a wing-nut or a bolt and nut, so it can be removed either by hand or with the correct sized wrench.
There should be slots to coil cutting line around, with a hole in each for line to be anchored. If no line is coiled around the part, insert the end of about three feet of cutting line into each of the holes, and coil the cutting line snugly around the part, making sure that there are no tangles in the line.
2 autres ont terminé cette réparation.
Un commentaire
It spins besept not with enough power to cut the grass why is
