Aller au contenu principal
Weinmann VENTImotion and VENTIlogic Display Board Replacement
Matériel médical
Ni iFixit ni ce tutoriel de réparation ne sont approuvés par ou affiliés au fabricant de ce dispositif médical.
Ce dont vous avez besoin
  1. Weinmann VENTImotion and VENTIlogic Display Board Replacement, Display Board: étape 1, image 1 de 2 Weinmann VENTImotion and VENTIlogic Display Board Replacement, Display Board: étape 1, image 2 de 2
    • Open the device by following these steps:
    • Place the device on a non-slip surface with the top facing downwards
    • Remove the filter cassette from the top part of the housing.
    • Undo and remove the 6 screws (34).
    • Open the bottom of the housing (35) away to the side.
    • Undo the connecting cables for the humidifier (42) and the alarm (43).
    • Make sure the power supply plug is disconnected.
  2. Weinmann VENTImotion and VENTIlogic Display Board Replacement: étape 3, image 1 de 1
    • Disconnect the following:
    • encoder connector (82).
    • connectors of interfaces (84) and (85) off the control board.
  3. Weinmann VENTImotion and VENTIlogic Display Board Replacement: étape 4, image 1 de 1
    • Disconnect the ribbon cable of the display and the fascia film.
    • Pull the latch out until you feel resistance. You can then pull out the ribbon cable.
    • If the latch has not been opened correctly, the ribbon cable may be damaged when it is pulled out.
  4. Weinmann VENTImotion and VENTIlogic Display Board Replacement: étape 5, image 1 de 1
    • Pull flow measurement hoses (56) off the flow sensor.
    • Pull pressure measurement hoses (57) off the pressure sensors.
  5. Weinmann VENTImotion and VENTIlogic Display Board Replacement: étape 6, image 1 de 1
    • Undo the four screws (51) and remove control board (50).
  6. Weinmann VENTImotion and VENTIlogic Display Board Replacement: étape 7, image 1 de 1
    • Remove spring (54) from the control board and remove battery (52) (see "7.9 Replace battery on control board" on page 42).
    • Remove display
  7. Weinmann VENTImotion and VENTIlogic Display Board Replacement: étape 9, image 1 de 1
    • Insert a new display (49).
    • The display may not tilt and must be straight in the guides.
Cameron Young
Membre depuis le 04/22/19
174 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S7-G19, Paton Spring 2020 Membre de l'équipe Cal Poly, Team S7-G19, Paton Spring 2020
CPSU-PATON-S20S7G19
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 11
Total : 102
