Aller au contenu principal
Wen 2307 Speed Adjustment Assembly Replacement
Ce dont vous avez besoin
  1. Wen 2307 Speed Adjustment Assembly Replacement, Front Panel: étape 1, image 1 de 1
    • Unscrew the locking sleeve.
  2. Wen 2307 Speed Adjustment Assembly Replacement: étape 2, image 1 de 1
    • Remove the hanging clip.
  3. Wen 2307 Speed Adjustment Assembly Replacement: étape 3, image 1 de 2 Wen 2307 Speed Adjustment Assembly Replacement: étape 3, image 2 de 2
    • Unscrew the six 8mm PH2 screws.
  4. Wen 2307 Speed Adjustment Assembly Replacement: étape 4, image 1 de 1
    • While pressing the spindle lock button, unscrew the collet nut and remove it along with the brass collet.
  5. Wen 2307 Speed Adjustment Assembly Replacement: étape 5, image 1 de 1
    • To remove the front panel, pry the device apart while holding the device with the other hand.
    • The front panel should come out easily.
  6. Wen 2307 Speed Adjustment Assembly Replacement, Power Cable: étape 6, image 1 de 2 Wen 2307 Speed Adjustment Assembly Replacement, Power Cable: étape 6, image 2 de 2
    • Identify the screws.
    • Unscrew the two 3mm phillips PH2.
    • Don't forget to put them appart from the ones unscrewed before.
    • Phillips PH2
    • Flathead 2.5mm
  7. Wen 2307 Speed Adjustment Assembly Replacement: étape 7, image 1 de 1
    • Remove the place boar carefully.
  8. Wen 2307 Speed Adjustment Assembly Replacement: étape 8, image 1 de 1
    • Pull out the power cable connectors.
  9. Wen 2307 Speed Adjustment Assembly Replacement: étape 9, image 1 de 1
    • Pull out the cord sleve for the new cable replacement.
  10. Wen 2307 Speed Adjustment Assembly Replacement, Speed Adjustment Assembly: étape 10, image 1 de 1
    • Remove the connected wiring from the circuit board.
  11. Wen 2307 Speed Adjustment Assembly Replacement: étape 11, image 1 de 1
    • Remove the single 4mm screw retaining the circuit board.
  12. Wen 2307 Speed Adjustment Assembly Replacement: étape 12, image 1 de 1
    • Gently pry the circuit board from the back piece.
2 autres ont terminé cette réparation.
Dominick Chavez
Membre depuis le 02/08/16
137 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 12-1, Eyestone Spring 2016 Membre de l'équipe USF Tampa, Team 12-1, Eyestone Spring 2016
USFT-EYESTONE-S16S12G1
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 12
Total : 728
