Aller au contenu principal
Wexford CT-166TF Air Filter Casing Replacement
Ce dont vous avez besoin
  1. Wexford CT-166TF Air Filter Casing Replacement, Air Filter Casing: étape 1, image 1 de 1
    • Using a plastic opening tool, remove the four small foam pieces on the bottom of the fan.
  2. Wexford CT-166TF Air Filter Casing Replacement: étape 2, image 1 de 3 Wexford CT-166TF Air Filter Casing Replacement: étape 2, image 2 de 3 Wexford CT-166TF Air Filter Casing Replacement: étape 2, image 3 de 3
    • Remove the four screws that were uncovered in the previous step.
    • Remove the bottom cover using a spudger if needed.
  3. Wexford CT-166TF Air Filter Casing Replacement: étape 3, image 1 de 1
    • Remove the five screws that can be seen by aligning the base and the fan.
  4. Wexford CT-166TF Air Filter Casing Replacement: étape 4, image 1 de 2 Wexford CT-166TF Air Filter Casing Replacement: étape 4, image 2 de 2
    • Stand the fan upright. Locate and remove the two screws near the top.
  5. Wexford CT-166TF Air Filter Casing Replacement: étape 5, image 1 de 2 Wexford CT-166TF Air Filter Casing Replacement: étape 5, image 2 de 2
    • Locate and remove the two bottom screws.
  6. Wexford CT-166TF Air Filter Casing Replacement: étape 6, image 1 de 1
    • Remove the back casing by pulling it away from the front casing.
  7. Wexford CT-166TF Air Filter Casing Replacement: étape 7, image 1 de 2 Wexford CT-166TF Air Filter Casing Replacement: étape 7, image 2 de 2
    • Remove the two screws attaching the motor to the front casing.
  8. Wexford CT-166TF Air Filter Casing Replacement: étape 8, image 1 de 2 Wexford CT-166TF Air Filter Casing Replacement: étape 8, image 2 de 2
    • Remove the two middle screws connecting the air filter casing to the front casing.
    • Remove the front casing.
  9. Wexford CT-166TF Air Filter Casing Replacement: étape 9, image 1 de 1
    • Remove the four remain screws holding the air filter casing together
  10. Wexford CT-166TF Air Filter Casing Replacement: étape 10, image 1 de 2 Wexford CT-166TF Air Filter Casing Replacement: étape 10, image 2 de 2
    • Put the new air filter casing in place after cleaning the filter.
    • Repeat steps 1-9 in reverse order to properly put back together the fan.
Dannis Thompson
Membre depuis le 04/10/17
261 Réputation
2 tutoriels rédigés
Équipe
UW Tacoma, Team S3-G4, Liner Spring 2017 Membre de l'équipe UW Tacoma, Team S3-G4, Liner Spring 2017
UWT-LINER-S17S3G4
4 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 19
Total : 614
