Aller au contenu principal
Whirlpool Dryer Steam Nozzle Replacement
Ce dont vous avez besoin
  1. Whirlpool Dryer Steam Nozzle Replacement, Safety Precautions: étape 1, image 1 de 1
    • Before you begin your repair, unplug your dryer.
    • Your power cord may have four prongs rather than three. The additional prong is a ground connection.
  2. Whirlpool Dryer Steam Nozzle Replacement, Unfasten the top panel: étape 2, image 1 de 3 Whirlpool Dryer Steam Nozzle Replacement, Unfasten the top panel: étape 2, image 2 de 3 Whirlpool Dryer Steam Nozzle Replacement, Unfasten the top panel: étape 2, image 3 de 3
    Outil utilisé dans cette étape :
    FixMat
    $36.95
    • Throughout this guide, keep track of each screw and reinstall it exactly where it came from.
    • Use a nut driver to remove the screws securing the top panel to the rear panel bracket.
  3. Whirlpool Dryer Steam Nozzle Replacement, Remove the top panel: étape 3, image 1 de 2 Whirlpool Dryer Steam Nozzle Replacement, Remove the top panel: étape 3, image 2 de 2
    • Grasp the top and slide it 1/2 to 1 inch toward the rear of the machine.
  4. Whirlpool Dryer Steam Nozzle Replacement: étape 4, image 1 de 2 Whirlpool Dryer Steam Nozzle Replacement: étape 4, image 2 de 2
    • Lift the top panel upward to separate it from the chassis.
    • Remove the top panel from the machine.
  5. Whirlpool Dryer Steam Nozzle Replacement, Unfasten the cover plate: étape 5, image 1 de 1
    • Remove the cover plate screw.
  6. Whirlpool Dryer Steam Nozzle Replacement, Remove the cover plate: étape 6, image 1 de 3 Whirlpool Dryer Steam Nozzle Replacement, Remove the cover plate: étape 6, image 2 de 3 Whirlpool Dryer Steam Nozzle Replacement, Remove the cover plate: étape 6, image 3 de 3
    • Remove the cover plate.
  7. Whirlpool Dryer Steam Nozzle Replacement, Disconnect the cord: étape 7, image 1 de 1
    • Remove the screws securing the cord cables.
    • Mark the cables with a permanent marker if needed and take a picture or draw a diagram.
  8. Whirlpool Dryer Steam Nozzle Replacement, Remove the cord: étape 8, image 1 de 3 Whirlpool Dryer Steam Nozzle Replacement, Remove the cord: étape 8, image 2 de 3 Whirlpool Dryer Steam Nozzle Replacement, Remove the cord: étape 8, image 3 de 3
    • Pull the cord carefully down through the round hole.
    • Make sure you replace the connections correctly when you reassemble.
  9. Whirlpool Dryer Steam Nozzle Replacement, Unfasten the cord terminal block: étape 9, image 1 de 1
    • Remove the green ground screw.
    • Remove the cord terminal block screws.
  10. Whirlpool Dryer Steam Nozzle Replacement, Move the cord terminal block: étape 10, image 1 de 3 Whirlpool Dryer Steam Nozzle Replacement, Move the cord terminal block: étape 10, image 2 de 3 Whirlpool Dryer Steam Nozzle Replacement, Move the cord terminal block: étape 10, image 3 de 3
    • Move the cord terminal block behind the rear panel.
  11. Whirlpool Dryer Steam Nozzle Replacement, Unfasten the rear panel: étape 11, image 1 de 2 Whirlpool Dryer Steam Nozzle Replacement, Unfasten the rear panel: étape 11, image 2 de 2
    FixMat
    $36.95
    • Remove the rear panel screws.
  12. Whirlpool Dryer Steam Nozzle Replacement: étape 12, image 1 de 2 Whirlpool Dryer Steam Nozzle Replacement: étape 12, image 2 de 2
    • Remove the screw holding the main board bracket to the chassis.
    • Remove the screws from the top rear of the machine.
  13. Whirlpool Dryer Steam Nozzle Replacement, Remove the rear panel: étape 13, image 1 de 3 Whirlpool Dryer Steam Nozzle Replacement, Remove the rear panel: étape 13, image 2 de 3 Whirlpool Dryer Steam Nozzle Replacement, Remove the rear panel: étape 13, image 3 de 3
    • Put on gloves before continuing, as the rear panel is sharp.
    • Lift the panel about 1/2 inch and tilt it to the rear to release it from the vent pipe.
    • Slide the panel off the vent pipe and remove it.
  14. Whirlpool Dryer Steam Nozzle Replacement, Reassembly information: étape 14, image 1 de 2 Whirlpool Dryer Steam Nozzle Replacement, Reassembly information: étape 14, image 2 de 2
    • During reassembly, perform the following:
    • Make sure that the vent pipe is fitted into the collar on the panel.
    • Make sure the tabs at the bottom are aligned to the bottom rim of the chassis.
    • Position the panel so its screw holes match with the chassis.
  15. Whirlpool Dryer Steam Nozzle Replacement, Disconnect the water tube: étape 15, image 1 de 3 Whirlpool Dryer Steam Nozzle Replacement, Disconnect the water tube: étape 15, image 2 de 3 Whirlpool Dryer Steam Nozzle Replacement, Disconnect the water tube: étape 15, image 3 de 3
    • Push the retaining clip out with a small screwdriver or spudger.
    • Grab the retaining clip with your fingertips and remove it.
  16. Whirlpool Dryer Steam Nozzle Replacement: étape 16, image 1 de 3 Whirlpool Dryer Steam Nozzle Replacement: étape 16, image 2 de 3 Whirlpool Dryer Steam Nozzle Replacement: étape 16, image 3 de 3
    • Press the yellow sleeve toward the valve to release the water tube.
    • While holding the sleeve in place, pull the water tube out of the sleeve
  17. Whirlpool Dryer Steam Nozzle Replacement, Unfasten the nozzle cover: étape 17, image 1 de 1
    • Remove the sheet metal screw securing the steam nozzle cover.
    • Be careful not to drop any tools as you work, or you may chip the drum's enamel coating
  18. Whirlpool Dryer Steam Nozzle Replacement, Remove the nozzle cover: étape 18, image 1 de 3 Whirlpool Dryer Steam Nozzle Replacement, Remove the nozzle cover: étape 18, image 2 de 3 Whirlpool Dryer Steam Nozzle Replacement, Remove the nozzle cover: étape 18, image 3 de 3
    • Lift the lower edge of the cover and tilt it outward to clear the nozzle.
    • Slide the cover down to disengage the tab at the upper end of the cover.
    • Remove the cover.
  19. Whirlpool Dryer Steam Nozzle Replacement, Unfasten nozzle assembly: étape 19, image 1 de 1
    • Remove the nozzle assembly screw.
  20. Whirlpool Dryer Steam Nozzle Replacement, Remove nozzle assembly: étape 20, image 1 de 3 Whirlpool Dryer Steam Nozzle Replacement, Remove nozzle assembly: étape 20, image 2 de 3 Whirlpool Dryer Steam Nozzle Replacement, Remove nozzle assembly: étape 20, image 3 de 3
    • Lift the nozzle assembly up to disengage the tab at the lower end.
    • Remove the nozzle assembly.
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
Membre depuis le 06/30/22
37 455 Réputation
261 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
118 membres
19 583 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 25
Total : 288
