Aller au contenu principal
Whirlpool Duet Sport Dryer F-01 fault control board repair
Ce dont vous avez besoin
    • Unplug the dryer from the wall outlet.
    • Remove the 2 screws securing the top panel.
    • Slide the top panel toward the back, then lift.
  1. Whirlpool Duet Sport Dryer F-01 fault control board repair, Remove the control board: étape 2, image 1 de 2 Whirlpool Duet Sport Dryer F-01 fault control board repair, Remove the control board: étape 2, image 2 de 2
    • Unplug the wires from the control board
    • Remove the 2 screws securing the control board assembly.
    • Remove the screw to free the control board.
    • Press the notch underneath the control board assembly then slide toward the front to remove the control board.
  2. Whirlpool Duet Sport Dryer F-01 fault control board repair, Remove control board housing: étape 3, image 1 de 2 Whirlpool Duet Sport Dryer F-01 fault control board repair, Remove control board housing: étape 3, image 2 de 2
    • Lift the 2 tabs to remove the cover.
    • Press the 6 tabs and lift the board up to free it from the enclosure.
    • Motor relay.
    • Heating element relay.
    • Motor relay surge supressor.
  3. Whirlpool Duet Sport Dryer F-01 fault control board repair, Remove components: étape 4, image 1 de 2 Whirlpool Duet Sport Dryer F-01 fault control board repair, Remove components: étape 4, image 2 de 2
    • Damage caused by heat generated by worn out relay contact.
    • Desolder and remove both relays, varistor and resistor.
    • Board with components removed. Relay terminal is in bad shape and melted on the board.
    • Clean the damaged soldering pads on both sides before installing new components.
  4. Whirlpool Duet Sport Dryer F-01 fault control board repair, Install new components: étape 5, image 1 de 2 Whirlpool Duet Sport Dryer F-01 fault control board repair, Install new components: étape 5, image 2 de 2
    • Install the new components.
    • Make sure there is good continuity between the 2 terminals and that the trace was not damaged by heat from the relay. If there is no continuity, add a good gage wire between the terminals as it carries the motor current.
Phil
Membre depuis le 08/25/10
163 Réputation
1 tutoriel rédigé
Un commentaire
Great post, thank you... We live in an age of vast dissemination of information, making everyone an expert in everything. I am assuming there is a hall effect sensor to ensure the drum is rotating as after pressing start, there is an audible click for the motor relay closing and if the drum does not rotate, there is couple of second delay before the code is thrown. Clearly on my gas Duet this was arcing awhile at the relay solder because of the scorching on the plastic housing and pcb. I cleaned up the trace and post with a brass brush, dab of flux, soldered it back up, checked continuity and drying clothes again.
Surfride10 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 17
Total : 269
