Aller au contenu principal
Whirlpool WRS571CIHV00 Lightbulb Replacement
Tutoriel Archivé
Ce tutoriel est conservé uniquement à des fins de suivis historiques. Utilisez la version actuelle du tutoriel pour effectuer votre réparation.
Ce dont vous avez besoin
  1. Whirlpool WRS571CIHV00 Lightbulb  Replacement, Lightbulb: étape 1, image 1 de 2 Whirlpool WRS571CIHV00 Lightbulb  Replacement, Lightbulb: étape 1, image 2 de 2
    • Pull the refrigerator out from the wall until you can safely slide behind it.
    • Unplug the refrigerator from its power source. This is normally found directly behind the refrigerator, just firmly grasp the plug and remove.
  2. Whirlpool WRS571CIHV00 Lightbulb  Replacement: étape 2, image 1 de 2 Whirlpool WRS571CIHV00 Lightbulb  Replacement: étape 2, image 2 de 2
    • Using the Phillips #1 screwdriver, remove the 1/2'' screw holding the plastic cover in place.
  3. Whirlpool WRS571CIHV00 Lightbulb  Replacement: étape 3, image 1 de 1
    • Pull back the plastic cover with your hand as shown in the figure.
    • You will want to hold this piece back for the next few steps as indicated in each step.
  4. Whirlpool WRS571CIHV00 Lightbulb  Replacement: étape 4, image 1 de 1
    • Twist the lightbulb to the left to loosen it from the receptacle.
    • You will still need to hold the plastic housing back so you can access the lightbulb.
  5. Whirlpool WRS571CIHV00 Lightbulb  Replacement: étape 5, image 1 de 1
    • Once loosened, remove the lightbulb from the receptacle and throw it away.
    • The lightbulb is fragile; therefore, handle it with care.
    • Again, your other hand will still be holding the plastic housing back from the receptacle.
  6. Whirlpool WRS571CIHV00 Lightbulb  Replacement: étape 6, image 1 de 1
    • Place the appropriate wattage and size lightbulb into the receptacle.
    • Whirlpool recommends a 2.0 or 3.6 watt lightbulb.
    • Using your other hand, continue to hold the plastic housing back to have better access to the receptacle.
  7. Whirlpool WRS571CIHV00 Lightbulb  Replacement: étape 7, image 1 de 1
    • Twist the lightbulb to the right to tighten the bulb back into the receptacle.
    • Your other hand should still be holding the plastic housing back.
  8. Whirlpool WRS571CIHV00 Lightbulb  Replacement: étape 8, image 1 de 1
    • Use the Phillips #1 to replace the 1/2'' screw back into the plastic cover and tighten it by twisting to the right.
  9. Whirlpool WRS571CIHV00 Lightbulb  Replacement: étape 9, image 1 de 1
    • Slide behind the refrigerator and place the plug back into the outlet.
    • To place the plug back in, align the prongs with the holes in the outlet and push until the plug is seated firmly against the outlet.
    • Push the refrigerator back against the wall.
    • It is important to not push the refrigerator all the way against the wall. In other words, leave an inch to a half a inch between the back of the refrigerator and wall.
Calie Eldred
Membre depuis le 10/08/20
193 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 629
