Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Why You Should Clean and Maintain Your Automatic Coffeemaker
Ce dont vous avez besoin
    • Remove all loose attachments such as the water tank, drip tray, and coffee beans. Open the machine using this guide.
    • Inspect the water hoses and internal components for any signs of contamination.
    • The hoses don’t always need to be replaced. Often, cleaning with a thin brush, detergent, and hot water is sufficient.
    Demander à FixBot
    Ajouter un commentaire
    • Remove the screw on the cover. Remove the cover.
    • Unscrew the brewing unit.
    • Carefully remove the brewing unit for inspection and cleaning.
    Demander à FixBot
  1. Demander à FixBot
    • Detach the drainage valve to check for internal contamination.
    • This guide shows, how to overhaul the drainage valve.
    Demander à FixBot
    • Pre-clean parts before placing them in an ultrasonic bath for deep cleaning.
    • If you don’t have access to an ultrasonic bath, clean all parts thoroughly with hot water and detergent. Avoid using a dishwasher.
    Demander à FixBot
    • Install new or cleaned hoses and replace any worn-out seals.
    • Thorough cleaning of the interior and exterior is necessary.
    Demander à FixBot
    • The coffee spout tends to become contaminated with coffee grease. If you want to remove it, you have to remove the spout, which can be quite time-consuming.
    Demander à FixBot
    • After cleaning and replacing necessary parts, reassemble the machine.
    • Run a cleaning and descaling cycle before brewing coffee again.
    Demander à FixBot
Repair didn't go as planned? Try some basic troubleshooting, or ask our Answers community for help.
eCuration
Membre depuis le 05/19/17
476 944 Réputation
385 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
123 membres
28 236 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 16
30 derniers jours : 84
Total : 2,150
