Introduction
This guide will help you to replace the LCD display. For this replacement, you will need to use a #00 Phillips screwdriver and a small tri-point (Y) screwdriver.
Ce dont vous avez besoin
Vidéo d'introduction
Place Gamepad face down and remove the two 4.7 mm screws with a Phillips size #00 screwdriver.
Remove 10 9mm screws with Tri-Wing size Y1 screwdriver around the outer case.
Lift up on the back of case.
Outil utilisé dans cette étape :Tweezers$4.99
Open the top and bottom clasp that connects the white flex cable to the motherboard with the tweezer.
Remove the white flex cable with the tweezers.
Disconnect the analog connector with tweezers.
Remove the four 5.1mm screws using Phillips size #0 screwdriver.
Pull the white and black cables away from the display case.
86 autres ont terminé cette réparation.
20 commentaires de tutoriel
was really perfect to repair my device. Thank you very much for this help
In step 14 - what does the small gray ribbon do? The replacement LCD display that I got in the mail did not have it.
Its the touch screen cable. The screen I ordered did not come with one. I had to carefully remove it from my broken display and put it on the new one. Thankfully the touchscreen still works for me.
Mine did not come with the touch screen either.
