Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Wolf Gourmet WGBL100S Power Cord Replacement
Ce dont vous avez besoin
    1. Wolf Gourmet WGBL100S Power Cord Replacement, Power Cord: étape 1, image 1 de 2 Wolf Gourmet WGBL100S Power Cord Replacement, Power Cord: étape 1, image 2 de 2
      • With the bottom of the blender facing up, use a Phillips #2 screwdriver to remove the 4, 1/2 inch long screws in the corners of the device.
      • Ensure the blender is off and unplugged before starting.
      Demander à FixBot
      Ajouter un commentaire
    2. Wolf Gourmet WGBL100S Power Cord Replacement: étape 2, image 1 de 2 Wolf Gourmet WGBL100S Power Cord Replacement: étape 2, image 2 de 2
      • Using a metal spudger, pry up one side of each of the rubber feet.
      • Note that one side of each foot is glued down; pry up the non-glued side.
      Demander à FixBot
    3. Wolf Gourmet WGBL100S Power Cord Replacement: étape 3, image 1 de 1
      • Using the same Phillips #2 screwdriver, unscrew the 1/2 inch long screw under each of the feet.
      Demander à FixBot
    4. Wolf Gourmet WGBL100S Power Cord Replacement: étape 4, image 1 de 2 Wolf Gourmet WGBL100S Power Cord Replacement: étape 4, image 2 de 2
      • Pull off the base and remove the plastic housing underneath.
      Demander à FixBot
    5. Wolf Gourmet WGBL100S Power Cord Replacement: étape 5, image 1 de 2 Wolf Gourmet WGBL100S Power Cord Replacement: étape 5, image 2 de 2
      • On the underside of the base, unscrew the three 3/8" long screws on the plastic piece holding the power cord in place using a Phillips #1 screwdriver.
      • Pull the plastic cover off.
      Demander à FixBot
    6. Wolf Gourmet WGBL100S Power Cord Replacement: étape 6, image 1 de 1
      • Using a wire cutter, cut the three wires of the power cord.
      Demander à FixBot
    7. Wolf Gourmet WGBL100S Power Cord Replacement: étape 7, image 1 de 2 Wolf Gourmet WGBL100S Power Cord Replacement: étape 7, image 2 de 2
      • Pull the cut power cord through the base.
      • Then thread the replacement cord back through and re-attach the plastic cover.
      Demander à FixBot
    8. Wolf Gourmet WGBL100S Power Cord Replacement: étape 8, image 1 de 3 Wolf Gourmet WGBL100S Power Cord Replacement: étape 8, image 2 de 3 Wolf Gourmet WGBL100S Power Cord Replacement: étape 8, image 3 de 3
      • Strip about an inch of insulation off of the snipped power cord and your replacement cord.
      • Twist each strand of wires together to keep them neat.
      Demander à FixBot
    9. Wolf Gourmet WGBL100S Power Cord Replacement: étape 9, image 1 de 2 Wolf Gourmet WGBL100S Power Cord Replacement: étape 9, image 2 de 2
      • Twist together the wires from the replacement cord to the wires still attached to the blender.
      • Solder the connection if possible.
      Demander à FixBot
    10. Wolf Gourmet WGBL100S Power Cord Replacement: étape 10, image 1 de 2 Wolf Gourmet WGBL100S Power Cord Replacement: étape 10, image 2 de 2
      • Wrap all the connections in electrical tape or heat shrink tubing.
      Demander à FixBot
To reassemble your device, follow steps 1-5 in reverse order.
Cole Gillespie
Membre depuis le 04/19/18
476 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S25-G16, Maness Spring 2018 Membre de l'équipe Cal Poly, Team S25-G16, Maness Spring 2018
CPSU-MANESS-S18S25G16
4 membres
60 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 33
Total : 671
