Introduction
If no electricity flows through the toaster when plugged in, try replacing the electrical connection with this guide.
Ce dont vous avez besoin
Using a wedge, pry off the rubber pieces on the bottom of each foot of the toaster.
Unscrew the ground wire using a Tri-point Y1 screwdriver. It is secured with an 8mm screw.
Un commentaire
Thank you for you work on this toaster. My customer is happy.
