Aller au contenu principal
Wolf Gourmet WGTR102S Slide Assist Plunger Replacement
Ce dont vous avez besoin
  1. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement, Outer Shell: étape 1, image 1 de 1
    • Using a wedge, pry off the rubber pieces on the bottom of each foot of the toaster.
  2. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: étape 2, image 1 de 1
    • Remove the eight 8mm screws on each toaster foot using a Tri-point Y1 screwdriver.
  3. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: étape 3, image 1 de 1
    • Remove the crumb collector located on the bottom of the toaster.
  4. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: étape 4, image 1 de 1
    • Remove the three 8mm screws using the Tri-point Y1 screwdriver.
  5. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: étape 5, image 1 de 1
    • Remove the two 8mm screws on the bottom of the slide lever using a Tri-point Y1 screwdriver.
    • Once the screws are removed, detach the black plastic cover on the bottom of the slide lever.
  6. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: étape 6, image 1 de 1
    • Remove the final 8mm screw in the slide lever.
    • The lever can now pull away from the entire unit.
  7. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: étape 7, image 1 de 1
    • Remove toaster's outer shell by lifting straight up.
    • Slowly remove the outer shell. Disconnect ground wire before fully separating the shell and inner components.
  8. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: étape 8, image 1 de 2 Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: étape 8, image 2 de 2
    • Disconnect the wire cluster that connects the lights and circuit board by pulling apart the two plastic connectors.
    • Remove the outer shell from the device.
  9. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement, Slide Assist Plunger: étape 9, image 1 de 1
    • Remove the top panel by bending the tabs on each side straight up.
  10. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: étape 10, image 1 de 1
    • Remove the two 8mm screws on the bottom of the plunger using a Tri-point Y1 screwdriver.
  11. Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: étape 11, image 1 de 2 Wolf Gourmet WGTR102S Slide Assist Plunger Replacement: étape 11, image 2 de 2
    • Remove the plunger from the device.
Ryan Funchess
Membre depuis le 04/19/18
697 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team S22-G5, Maness Spring 2018 Membre de l'équipe Cal Poly, Team S22-G5, Maness Spring 2018
CPSU-MANESS-S18S22G5
4 membres
5 tutoriels rédigés
4 commentaires
Where does one get a new plunger for the replacement?
hsernaker - Réponse
yes, where does one get a new pludger?
hiyar124 - Réponse
Has anyone found a source for the WOLF toaster plunger?
Rick Guest - Réponse
Any pointers on where to find Wolf replacement parts ?
Stefano Concina - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 16
Total : 1,073
