Aller au contenu principal
Wolfgang Puck Pie Maker Disassembly
Ce dont vous avez besoin
  1. Wolfgang Puck Pie Maker Disassembly, Wolfgang Puck Pie Maker Disassembly: étape 1, image 1 de 1
    • Open up the pie maker using the two main handles so it's open as shown in the picture.
  2. Wolfgang Puck Pie Maker Disassembly: étape 2, image 1 de 2 Wolfgang Puck Pie Maker Disassembly: étape 2, image 2 de 2
    • Remove the four 12.7 mm screws from each handle using a Phillips #2 screwdriver.
    • Remove the inside handle cover.
  3. Wolfgang Puck Pie Maker Disassembly: étape 3, image 1 de 2 Wolfgang Puck Pie Maker Disassembly: étape 3, image 2 de 2
    • Remove the two 12.7 mm screws from the base of the pie maker using a Phillips #2 screwdriver.
    • This will allow for visibility into the wiring in the base.
  4. Wolfgang Puck Pie Maker Disassembly: étape 4, image 1 de 2 Wolfgang Puck Pie Maker Disassembly: étape 4, image 2 de 2
    • Remove the four 15.9 mm screws from the hinges using a Phillips #2 screwdriver.
    • Remove the top cover by pulling it off of the device.
  5. Wolfgang Puck Pie Maker Disassembly: étape 5, image 1 de 2 Wolfgang Puck Pie Maker Disassembly: étape 5, image 2 de 2
    • You now have access to the wiring underneath the top and bottom of the device.
    • To access the wiring, lift the metal burner part out of the base. The wiring will be visible on the opposite side, attached to the heating coil.
    • The temperature sensor can be accessed by lifting the bottom side of the device as shown.
Jake D. Freedman
Membre depuis le 09/16/20
171 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 207
