Aller au contenu principal
Womier K66 Mechanical Keyboard Switch Replacement
Ce dont vous avez besoin
  1. Womier K66 Mechanical Keyboard Switch Replacement, Switch: étape 1, image 1 de 3 Womier K66 Mechanical Keyboard Switch Replacement, Switch: étape 1, image 2 de 3 Womier K66 Mechanical Keyboard Switch Replacement, Switch: étape 1, image 3 de 3
    • Remove the keycaps from the keyboard using the keycap remover.
  2. Womier K66 Mechanical Keyboard Switch Replacement: étape 2, image 1 de 3 Womier K66 Mechanical Keyboard Switch Replacement: étape 2, image 2 de 3 Womier K66 Mechanical Keyboard Switch Replacement: étape 2, image 3 de 3
    • Flip the keyboard over so the backside is facing up.
    • Use the Phillips #0 screwdriver to remove the fourteen 1.52 mm screws.
    • Remove the back plate of the keyboard.
  3. Womier K66 Mechanical Keyboard Switch Replacement: étape 3, image 1 de 3 Womier K66 Mechanical Keyboard Switch Replacement: étape 3, image 2 de 3 Womier K66 Mechanical Keyboard Switch Replacement: étape 3, image 3 de 3
    Outil utilisé dans cette étape :
    Desoldering Pump
    $3.99
    J'achète
    • If you're unfamiliar with solder or need a refresher, review the How to Solder and Desolder guide.
    • Set your soldering iron to 400 °C.
    • Apply the soldering iron to the solder joints and remove the solder with the desoldering pump.
    • Be careful when soldering as the iron is very hot.
  4. Womier K66 Mechanical Keyboard Switch Replacement: étape 4, image 1 de 3 Womier K66 Mechanical Keyboard Switch Replacement: étape 4, image 2 de 3 Womier K66 Mechanical Keyboard Switch Replacement: étape 4, image 3 de 3
    • Remove the key switch from the board using the key switch puller.
  5. Womier K66 Mechanical Keyboard Switch Replacement: étape 5, image 1 de 3 Womier K66 Mechanical Keyboard Switch Replacement: étape 5, image 2 de 3 Womier K66 Mechanical Keyboard Switch Replacement: étape 5, image 3 de 3
    • Place your new switch onto the board.
    • In this case we used a Gateron Linear switch but this could be any variety of switches.
  6. Womier K66 Mechanical Keyboard Switch Replacement: étape 6, image 1 de 3 Womier K66 Mechanical Keyboard Switch Replacement: étape 6, image 2 de 3 Womier K66 Mechanical Keyboard Switch Replacement: étape 6, image 3 de 3
    • Apply new solder to the soldering joints of the replacement switch.
Minh-Tam Nguyen
Membre depuis le 11/03/22
133 Réputation
1 tutoriel rédigé
Équipe
York University, Team B-7, Allen Fall 2022 Membre de l'équipe York University, Team B-7, Allen Fall 2022
YORK-ALLEN-F22SBG7
3 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 22
Total : 470
