Aller au contenu principal
Wood Stool Leg Glide Replacement
Ce dont vous avez besoin
  1. Wood Stool Leg Glide Replacement, Wood Stool Leg Glides: étape 1, image 1 de 1
    • Turn the stool upside down so it is stable on the ground and the legs are faced up in the air.
  2. Wood Stool Leg Glide Replacement: étape 2, image 1 de 1
    • Clean the end of the sled gliders and the legs to remove dust and debris.
  3. Wood Stool Leg Glide Replacement: étape 3, image 1 de 1
    • Peel the sled glides off of the top of the screw on glides on all four of the legs.
  4. Wood Stool Leg Glide Replacement: étape 4, image 1 de 1
    • Use a 1.59mm drill bit and unscrew the screw from all four legs. Then remove the screw on glides.
    • Make sure the drill is faced straight up and down or the screw will become stripped.
  5. Wood Stool Leg Glide Replacement: étape 5, image 1 de 1
    • Pry the remaining part of the screw with a hammer if the screw is not drilled out all of the way.
  6. Wood Stool Leg Glide Replacement: étape 6, image 1 de 1
    • Use a 1.59mm drill bit to drill on the new screw on glides in the center of all four stool legs.
  7. Wood Stool Leg Glide Replacement: étape 7, image 1 de 2 Wood Stool Leg Glide Replacement: étape 7, image 2 de 2
    • Stick the new sled glider at the center of the screw on glides for all four legs.
Molly Ristig
Membre depuis le 10/07/19
145 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 10
Total : 404
