Aller au contenu principal
Wooting 60HE Keycap Replacement
Ce dont vous avez besoin
  1. Wooting 60HE Keycap Replacement, Keycap: étape 1, image 1 de 1
    • Use a small, soft bristle brush to remove small hairs or dust from the keyboard.
    • For this replacement, we will be replacing the "A" keycap.
  2. Wooting 60HE Keycap Replacement: étape 2, image 1 de 2 Wooting 60HE Keycap Replacement: étape 2, image 2 de 2
    • Hook the two metal brackets of the keycap puller at a slight angle on the corners of the key.
    • Slightly tug upwards, and the key should come out smoothly. Place the key to the side.
    • It is essential to be gentle; excessive force can cause cracks or scratches on the key.
  3. Wooting 60HE Keycap Replacement: étape 3, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Using tweezers, carefully extract debris from the exposed backboard of the keyboard.
    • Try to avoid the key nub, as it is lubricated, and outside contact can ruin it.
  4. Wooting 60HE Keycap Replacement: étape 4, image 1 de 1
    • Hold a multi-purpose electronics duster three inches away and at an angle from the exposed key.
    • Press the trigger in short bursts.
    • This will help get rid of any debris that you could not get from using your tweezers.
  5. Wooting 60HE Keycap Replacement: étape 5, image 1 de 2 Wooting 60HE Keycap Replacement: étape 5, image 2 de 2
    • Place a cotton swab on a napkin and lightly coat the head of the swab with 70% isopropyl alcohol.
  6. Wooting 60HE Keycap Replacement: étape 6, image 1 de 1
    • Gently pat around the white backboard of the keyboard with the cotton swab.
    • This will help get rid of any built up residue, oils, or any possible spills that could have occurred in the past.
    • Isopropyl alcohol can strip the lubricant on the key, so put emphasis on dabbing the white backboard and not the key itself.
  7. Wooting 60HE Keycap Replacement: étape 7, image 1 de 3 Wooting 60HE Keycap Replacement: étape 7, image 2 de 3 Wooting 60HE Keycap Replacement: étape 7, image 3 de 3
    • Line the keycap in the upright position above the nub and press down lightly.
    • The key should slide back in place.
Ligne d'arrivée
Aryav Balia
Membre depuis le 10/25/23
157 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 1-1, Briggs Fall 2023 Membre de l'équipe CSU Los Angeles, Team 1-1, Briggs Fall 2023
CSULA-BRIGGS-F23S1G1
6 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 33
Total : 346
