Aller au contenu principal
World Dryer Airforce J4-973A3 Air Filter Replacement
Ce dont vous avez besoin
  1. World Dryer Airforce J4-973A3 Air Filter Replacement, Air Filter: étape 1, image 1 de 3 World Dryer Airforce J4-973A3 Air Filter Replacement, Air Filter: étape 1, image 2 de 3 World Dryer Airforce J4-973A3 Air Filter Replacement, Air Filter: étape 1, image 3 de 3
    • In order to change the air filter, start with the removal of the outer metal casing. Use the appropriate security bit.
    • Using the special bit, remove the large screws at the bottom of the casing.
    • To remove the case, lift the indicated spot with your hands.
    • The direction for turning the screws is different than what was indicated on the small sticker above the hole.
  2. World Dryer Airforce J4-973A3 Air Filter Replacement: étape 2, image 1 de 3 World Dryer Airforce J4-973A3 Air Filter Replacement: étape 2, image 2 de 3 World Dryer Airforce J4-973A3 Air Filter Replacement: étape 2, image 3 de 3
    • To access both filters, unscrew all three 1/2" Ph2 screws.
    • Gently pull the plate away from the black, coarse filter.
  3. World Dryer Airforce J4-973A3 Air Filter Replacement: étape 3, image 1 de 2 World Dryer Airforce J4-973A3 Air Filter Replacement: étape 3, image 2 de 2
    • After removing the small grey filter, pull on the black, ring-shaped filter to remove it.
    • We recommend either vacuuming the filters or washing them to remove the dust that has accumulated on the filter.
    • Leave the filters out to dry for 24 hours before putting it back into use, in order to avoid water damage or electric shock!
Blane Hirsh
Membre depuis le 09/17/18
260 Réputation
2 tutoriels rédigés
Équipe
Washington State, Team S1-G6, Hope Fall 2018 Membre de l'équipe Washington State, Team S1-G6, Hope Fall 2018
WSU-HOPE-F18S1G6
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 14
Total : 234
