Aller au contenu principal
World Dryer Airforce J4-973A3 Motor Replacement
Ce dont vous avez besoin
  1. World Dryer Airforce J4-973A3 Motor Replacement, Motor: étape 1, image 1 de 3 World Dryer Airforce J4-973A3 Motor Replacement, Motor: étape 1, image 2 de 3 World Dryer Airforce J4-973A3 Motor Replacement, Motor: étape 1, image 3 de 3
    • To change the motor, start by removing the metal casing.
    • Using the special bit, remove the large screws at the bottom of the casing.
    • To remove the case, lift the indicated spot with your hands.
    • The direction for turning the screws is different than what was indicated on the small sticker above the hole.
  2. World Dryer Airforce J4-973A3 Motor Replacement: étape 2, image 1 de 3 World Dryer Airforce J4-973A3 Motor Replacement: étape 2, image 2 de 3 World Dryer Airforce J4-973A3 Motor Replacement: étape 2, image 3 de 3
    • Remove the three 1/2" Ph1 screws at the bottom of the red fan cap.
    • Turn over the device.
    • Push the red tabs on the back of the unit with medium to heavy pressure, using a small prier.
    • Carefully remove the cap, to prevent damage to the sensor.
  3. World Dryer Airforce J4-973A3 Motor Replacement: étape 3, image 1 de 2 World Dryer Airforce J4-973A3 Motor Replacement: étape 3, image 2 de 2
    • Remove both 3/8" Ph2 screws attached to the grey belt at the top and bottom.
    • Lift the grey belt away. This gives access to the server board.
  4. World Dryer Airforce J4-973A3 Motor Replacement: étape 4, image 1 de 1
    • Use a plastic opening tool to remove the two pink capped wires in the upper left corner of the server board.
  5. World Dryer Airforce J4-973A3 Motor Replacement: étape 5, image 1 de 3 World Dryer Airforce J4-973A3 Motor Replacement: étape 5, image 2 de 3 World Dryer Airforce J4-973A3 Motor Replacement: étape 5, image 3 de 3
    • Remove the brass nut from its bolt using a 10mm wrench.
    • Once the nut is free, disconnect the green wire.
  6. World Dryer Airforce J4-973A3 Motor Replacement: étape 6, image 1 de 3 World Dryer Airforce J4-973A3 Motor Replacement: étape 6, image 2 de 3 World Dryer Airforce J4-973A3 Motor Replacement: étape 6, image 3 de 3
    • Remove the rainbow ribbon cable using a plastic opening tool.
    • Remove the 1/2" Ph1 screw from the center of the circuit board.
  7. World Dryer Airforce J4-973A3 Motor Replacement: étape 7, image 1 de 3 World Dryer Airforce J4-973A3 Motor Replacement: étape 7, image 2 de 3 World Dryer Airforce J4-973A3 Motor Replacement: étape 7, image 3 de 3
    • Remove the four 3/4" Ph2 screws from the back of the device body.
    • Separate the motor housing from the device body.
    • Ensure that all wires connecting the motor housing and motherboard are disconnected before removing the component.
  8. World Dryer Airforce J4-973A3 Motor Replacement: étape 8, image 1 de 3 World Dryer Airforce J4-973A3 Motor Replacement: étape 8, image 2 de 3 World Dryer Airforce J4-973A3 Motor Replacement: étape 8, image 3 de 3
    • Remove the four 1/2" Ph2 screws from the filter.
    • Pull the filter plate away to reveal the motor.
  9. World Dryer Airforce J4-973A3 Motor Replacement: étape 9, image 1 de 3 World Dryer Airforce J4-973A3 Motor Replacement: étape 9, image 2 de 3 World Dryer Airforce J4-973A3 Motor Replacement: étape 9, image 3 de 3
    • Pull the motor out of the housing.
    • Be sure to feed the wires through the slot as you pull the motor out.
Eli Forbes
Membre depuis le 09/17/18
172 Réputation
1 tutoriel rédigé
Équipe
Washington State, Team S1-G6, Hope Fall 2018 Membre de l'équipe Washington State, Team S1-G6, Hope Fall 2018
WSU-HOPE-F18S1G6
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 11
Total : 302
