Aller au contenu principal
World Dryer Airforce J4-973A3 Server Board Replacement
Ce dont vous avez besoin
  1. World Dryer Airforce J4-973A3 Server Board Replacement, Server Board: étape 1, image 1 de 3 World Dryer Airforce J4-973A3 Server Board Replacement, Server Board: étape 1, image 2 de 3 World Dryer Airforce J4-973A3 Server Board Replacement, Server Board: étape 1, image 3 de 3
    • Begin by removing both screws and the brushed metal casing. Simply lift up at the indicated area with your hand.
    • The INSTALL and REMOVE indicators may be incorrect, so exercise caution when removing the screws.
  2. World Dryer Airforce J4-973A3 Server Board Replacement: étape 2, image 1 de 2 World Dryer Airforce J4-973A3 Server Board Replacement: étape 2, image 2 de 2
    • Remove both 3/8" Ph2 screws attached to the grey belt at the top and bottom.
    • Lift the grey belt away. This gives access to the server board.
  3. World Dryer Airforce J4-973A3 Server Board Replacement: étape 3, image 1 de 3 World Dryer Airforce J4-973A3 Server Board Replacement: étape 3, image 2 de 3 World Dryer Airforce J4-973A3 Server Board Replacement: étape 3, image 3 de 3
    • Remove all three 1/2" Ph1 screws connecting the server board to the device.
    • During reassembly, install the screws before reattaching the wires.
  4. World Dryer Airforce J4-973A3 Server Board Replacement: étape 4, image 1 de 3 World Dryer Airforce J4-973A3 Server Board Replacement: étape 4, image 2 de 3 World Dryer Airforce J4-973A3 Server Board Replacement: étape 4, image 3 de 3
    • Use a plastic opening tool to remove the two pink capped wires in the upper left corner of the server board.
    • Use the same tool to dislodge the white capped ribbon bus with the multi-colored wires.
    • After these steps, the server board should easily come off the side of the device.
Blane Hirsh
Membre depuis le 09/17/18
260 Réputation
2 tutoriels rédigés
Équipe
Washington State, Team S1-G6, Hope Fall 2018 Membre de l'équipe Washington State, Team S1-G6, Hope Fall 2018
WSU-HOPE-F18S1G6
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 8
Total : 269
