Aller au contenu principal
WowWee CHiP Robot Dog Wheel Replacement
Ce dont vous avez besoin
  1. WowWee CHiP Robot Dog Wheel Replacement, Battery: étape 1, image 1 de 1
    • Place CHiP on its back so that its stomach is facing you.
  2. WowWee CHiP Robot Dog Wheel Replacement: étape 2, image 1 de 2 WowWee CHiP Robot Dog Wheel Replacement: étape 2, image 2 de 2
    • There are three small hex screws connecting the battery to CHiP. Remove all screws with a hex screwdriver and remove battery casing.
  3. WowWee CHiP Robot Dog Wheel Replacement: étape 3, image 1 de 2 WowWee CHiP Robot Dog Wheel Replacement: étape 3, image 2 de 2
    • Once the top face of the battery is off, you will see a small rectangular box that the batteries are inside. There are 4 Phillips head screws in the box. Remove all screws with a Phillips head screwdriver.
  4. WowWee CHiP Robot Dog Wheel Replacement: étape 4, image 1 de 3 WowWee CHiP Robot Dog Wheel Replacement: étape 4, image 2 de 3 WowWee CHiP Robot Dog Wheel Replacement: étape 4, image 3 de 3
    • Once the battery is removed from body, the battery should be connected by a red and black wire. There is a red rectangular connector that easily pulls apart. Pull apart the red rectangular connector.
  5. WowWee CHiP Robot Dog Wheel Replacement, Wheel: étape 5, image 1 de 1
    • Locate wheel to replace.
  6. WowWee CHiP Robot Dog Wheel Replacement: étape 6, image 1 de 1
    • Twist grey wheel cap in counter-clockwise rotation.
  7. WowWee CHiP Robot Dog Wheel Replacement: étape 7, image 1 de 1
    • Pull and remove wheel.
3 autres ont terminé cette réparation.
Joseph Dantes
Membre depuis le 10/02/18
514 Réputation
4 tutoriels rédigés
Équipe
2 commentaires
Why do you have to disconnect the battery before changing the wheel? Can you not just turn off the power and change it?
shawna_beji - Réponse
зачем снимать акб?
замена или снятие колес происходит при простом отключении устройства обычным выключателем.
Руслан Смоленск - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 46
Total : 3,915
