Aller au contenu principal
WowWee MiP Robot LED Light Replacement
Ce dont vous avez besoin
  1. WowWee MiP Robot LED Light Replacement, Battery: étape 1, image 1 de 2 WowWee MiP Robot LED Light Replacement, Battery: étape 1, image 2 de 2
    • Remove the three 12.0 mm Phillips # 2 screws from the battery cover.
  2. WowWee MiP Robot LED Light Replacement: étape 2, image 1 de 2 WowWee MiP Robot LED Light Replacement: étape 2, image 2 de 2
    • Carefully pull the battery pack from the robot.
    • Remove the batteries from the battery pack.
  3. WowWee MiP Robot LED Light Replacement, Wheel: étape 3, image 1 de 2 WowWee MiP Robot LED Light Replacement, Wheel: étape 3, image 2 de 2
    • Use a metal spudger to carefully pry off the hubcap without marring the plastic wheel or hubcap.
    • This plastic material is not replaceable. Any damage will be noticeable.
  4. WowWee MiP Robot LED Light Replacement: étape 4, image 1 de 2 WowWee MiP Robot LED Light Replacement: étape 4, image 2 de 2
    • Remove the 12.0 mm Phillips #2 screw.
    • Hold the wheel in place, or it will rotate as you attempt to remove the screw.
  5. WowWee MiP Robot LED Light Replacement: étape 5, image 1 de 1
    • Pull the wheel off of the square axle.
    • Do not use excessive force while removing the wheel. Pulling too hard on the wheel can damage the axle.
  6. WowWee MiP Robot LED Light Replacement, WowWee MiP Robot Body Disassembly: étape 6, image 1 de 2 WowWee MiP Robot LED Light Replacement, WowWee MiP Robot Body Disassembly: étape 6, image 2 de 2
    • Remove the eight 9.3 mm Phillips #1 screws from the back of the robot.
  7. WowWee MiP Robot LED Light Replacement: étape 7, image 1 de 3 WowWee MiP Robot LED Light Replacement: étape 7, image 2 de 3 WowWee MiP Robot LED Light Replacement: étape 7, image 3 de 3
    • Remove the arms from the body.
    • Carefully open the body compartment.
    • Open the compartment slowly. There are wires connecting the two body pieces together. If pulled too hard, the wires and/or the motherboard could be damaged.
  8. WowWee MiP Robot LED Light Replacement: étape 8, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Using precision tweezers, disconnect the following three bundles of wires:
    • Connecting the battery pack to the motherboard.
    • Connecting the power switch to the motherboard.
    • Connecting the speaker to the motherboard.
  9. WowWee MiP Robot LED Light Replacement, LED Light: étape 9, image 1 de 2 WowWee MiP Robot LED Light Replacement, LED Light: étape 9, image 2 de 2
    • Remove the four 7.5mm Phillips #1 screws.
  10. WowWee MiP Robot LED Light Replacement: étape 10, image 1 de 2 WowWee MiP Robot LED Light Replacement: étape 10, image 2 de 2
    • Carefully pull the motor and motherboard assembly straight out from the base.
    • Be careful not to break the plastic rods that go through the motor assembly and are connect to the shell.
  11. WowWee MiP Robot LED Light Replacement: étape 11, image 1 de 1
    J'achète
    • Use the precision tweezers to unplug the bundle of wires.
  12. WowWee MiP Robot LED Light Replacement: étape 12, image 1 de 1
    • Slide the head back to separate it from the body.
    • The motherboard does not need to be separated from the head to replace the LED light.
  13. WowWee MiP Robot LED Light Replacement: étape 13, image 1 de 1
    • Remove the 7.5mm Phillips #1 screw.
    • The LED light is soldered to the small circuit board.
Courtney
Membre depuis le 02/04/16
236 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 3-4, Wollert Spring 2016 Membre de l'équipe USF Tampa, Team 3-4, Wollert Spring 2016
USFT-WOLLERT-S16S3G4
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 8
Total : 630
