Aller au contenu principal
WowWee MiP Robot Power Switch Replacement
Ce dont vous avez besoin
  1. WowWee MiP Robot Power Switch Replacement, Battery: étape 1, image 1 de 2 WowWee MiP Robot Power Switch Replacement, Battery: étape 1, image 2 de 2
    • Remove the three 12.0 mm Phillips # 2 screws from the battery cover.
  2. WowWee MiP Robot Power Switch Replacement: étape 2, image 1 de 2 WowWee MiP Robot Power Switch Replacement: étape 2, image 2 de 2
    • Carefully pull the battery pack from the robot.
    • Remove the batteries from the battery pack.
  3. WowWee MiP Robot Power Switch Replacement, Wheel: étape 3, image 1 de 2 WowWee MiP Robot Power Switch Replacement, Wheel: étape 3, image 2 de 2
    • Use a metal spudger to carefully pry off the hubcap without marring the plastic wheel or hubcap.
    • This plastic material is not replaceable. Any damage will be noticeable.
  4. WowWee MiP Robot Power Switch Replacement: étape 4, image 1 de 2 WowWee MiP Robot Power Switch Replacement: étape 4, image 2 de 2
    • Remove the 12.0 mm Phillips #2 screw.
    • Hold the wheel in place, or it will rotate as you attempt to remove the screw.
  5. WowWee MiP Robot Power Switch Replacement: étape 5, image 1 de 1
    • Pull the wheel off of the square axle.
    • Do not use excessive force while removing the wheel. Pulling too hard on the wheel can damage the axle.
  6. WowWee MiP Robot Power Switch Replacement, WowWee MiP Robot Body Disassembly: étape 6, image 1 de 2 WowWee MiP Robot Power Switch Replacement, WowWee MiP Robot Body Disassembly: étape 6, image 2 de 2
    • Remove the eight 9.3 mm Phillips #1 screws from the back of the robot.
  7. WowWee MiP Robot Power Switch Replacement: étape 7, image 1 de 3 WowWee MiP Robot Power Switch Replacement: étape 7, image 2 de 3 WowWee MiP Robot Power Switch Replacement: étape 7, image 3 de 3
    • Remove the arms from the body.
    • Carefully open the body compartment.
    • Open the compartment slowly. There are wires connecting the two body pieces together. If pulled too hard, the wires and/or the motherboard could be damaged.
  8. WowWee MiP Robot Power Switch Replacement: étape 8, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Using precision tweezers, disconnect the following three bundles of wires:
    • Connecting the battery pack to the motherboard.
    • Connecting the power switch to the motherboard.
    • Connecting the speaker to the motherboard.
  9. WowWee MiP Robot Power Switch Replacement, Power Switch: étape 9, image 1 de 2 WowWee MiP Robot Power Switch Replacement, Power Switch: étape 9, image 2 de 2
    • Remove the two 9.3mm Phillips #1 screws.
  10. WowWee MiP Robot Power Switch Replacement: étape 10, image 1 de 1
    • Remove the power switch assembly from the body by gently pulling straight out on the wires.
2 autres ont terminé cette réparation.
Daniel Burkholder
Membre depuis le 02/16/16
623 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 3-4, Wollert Spring 2016 Membre de l'équipe USF Tampa, Team 3-4, Wollert Spring 2016
USFT-WOLLERT-S16S3G4
4 membres
10 tutoriels rédigés
Un commentaire
where can i buy the power switch of MiP
Reinejoe Cacho - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 621
