Aller au contenu principal
Wyze Cam V2 Charging Port Replacement
Ce dont vous avez besoin
  1. Wyze Cam V2 Charging Port Replacement, Back Panel: étape 1, image 1 de 1
    • Open up the camera stand to expose the bottom plate of the camera.
    • Remove two 4 mm silver screws using the Phillips #0 screwdriver.
  2. Wyze Cam V2 Charging Port Replacement: étape 2, image 1 de 1
    • Using the iFixit opening tool, carefully pry open the bottom plate to gain access to the camera's internals.
  3. Wyze Cam V2 Charging Port Replacement: étape 3, image 1 de 2 Wyze Cam V2 Charging Port Replacement: étape 3, image 2 de 2
    • Open up the back panel using the iFixit opening tool and unclip the panel from the rest of the device.
    • Be careful of the charging port while taking it off.
  4. Wyze Cam V2 Charging Port Replacement: étape 4, image 1 de 2 Wyze Cam V2 Charging Port Replacement: étape 4, image 2 de 2
    Outil utilisé dans cette étape :
    $3.99
    J'achète
  5. Wyze Cam V2 Charging Port Replacement, Motherboard: étape 5, image 1 de 1
    • Remove the single 6 mm screw located deep inside the device using a Phillips #000 screwdriver.
    • Carefully remove the motherboard from the device.
  6. Wyze Cam V2 Charging Port Replacement: étape 6, image 1 de 1
    • Remove the remaining two 6 mm screws from the motherboard with a Phillips #0 screwdriver.
  7. Wyze Cam V2 Charging Port Replacement: étape 7, image 1 de 1
    J'achète
    • Using the precision tweezers, detach the charging port’s motherboard from the camera’s motherboard.
  8. Wyze Cam V2 Charging Port Replacement, Charging Port: étape 8, image 1 de 1
    • Desolder the iron piece holding the charging port in place.
  9. Wyze Cam V2 Charging Port Replacement: étape 9, image 1 de 1
    • Carefully detach the charging port from the motherboard.
Montserrat Esquivel
Membre depuis le 09/12/23
303 Réputation
3 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 51
