Introduction
The Wyze Cam V2's speaker is responsible for producing sound and is an important part of the system. If your cam's audio is muffled or completely absent, the speaker may need to be replaced. This guide will help walk you through the steps of replacing a non-functioning speaker.
Ce dont vous avez besoin
Open up the camera stand to expose the bottom plate of the camera.
Remove two 4 mm silver screws using the Phillips #0 screwdriver.
Outil utilisé dans cette étape :Tweezers$3.99
Using the angled slim tweezers, disconnect the cord and pull it gently off of the motherboard.
Remove the two 6 mm screws from the back cover with a Phillips #0 screwdriver.
Carefully lift off the speaker plate.
