Aller au contenu principal
Wyze WVCR200s Battery Replacement
Ce dont vous avez besoin
  1. Wyze WVCR200s Battery Replacement, Rotating Brush: étape 1, image 1 de 1
    • Flip the vacuum upside down so the bottom is facing up.
    • In the center of the device, you should see the rotating brush that stretches from one wheel to the other.
  2. Wyze WVCR200s Battery Replacement: étape 2, image 1 de 2 Wyze WVCR200s Battery Replacement: étape 2, image 2 de 2
    • Pinch the blue tabs below the rotating brush towards each other.
    • Lift the plastic housing surrounding the rotating brushing straight up, and the remove it from the vacuum.
  3. Wyze WVCR200s Battery Replacement: étape 3, image 1 de 3 Wyze WVCR200s Battery Replacement: étape 3, image 2 de 3 Wyze WVCR200s Battery Replacement: étape 3, image 3 de 3
    • To remove the rotating brush, lift one end of the brush upwards, and remove.
  4. Wyze WVCR200s Battery Replacement, Battery: étape 4, image 1 de 1
    • Use a screwdriver to remove four screws along the edge, just above where the brush was removed.
  5. Wyze WVCR200s Battery Replacement: étape 5, image 1 de 1
    • Lift the battery cover up and out of the vacuum.
  6. Wyze WVCR200s Battery Replacement: étape 6, image 1 de 2 Wyze WVCR200s Battery Replacement: étape 6, image 2 de 2
    • Lift the battery out from underneath the cover.
    • Be careful not to pull or yank the battery out, it is connected by wires to the vacuum port.
    • Carefully disconnect the battery from the vacuum port.
Brandon Amado
Membre depuis le 03/20/23
411 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 5-5, Ramos Spring 2023 Membre de l'équipe UMass Dartmouth, Team 5-5, Ramos Spring 2023
UMASSD-RAMOS-S23S5G5
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 29
30 derniers jours : 140
Total : 1,453
