Aller au contenu principal
Wyze WVCR200s Bumper Replacement
Ce dont vous avez besoin
  1. Wyze WVCR200s Bumper Replacement, Side Brush: étape 1, image 1 de 1
    • Flip the vacuum upside down so the underside of the device is facing up.
    • On the upper left of the device, you should see a spinning brush with three arms protruding out. This is the side brush.
  2. Wyze WVCR200s Bumper Replacement: étape 2, image 1 de 1
    • To remove, grab the three arms of the brush and pull upwards. The arms should be tight, but should not require too much force to lift off.
    • Once the brush is off, a square peg that holds the brush should be visible.
    • Place the replacement brush on the square peg, and press down with moderate pressure.
  3. Wyze WVCR200s Bumper Replacement, Bumper: étape 3, image 1 de 1
    • Flip the vacuum over.
  4. Wyze WVCR200s Bumper Replacement: étape 4, image 1 de 1
    • Use a Phillips screwdriver to remove the six screws along the bottom edge of the bumper.
  5. Wyze WVCR200s Bumper Replacement: étape 5, image 1 de 3 Wyze WVCR200s Bumper Replacement: étape 5, image 2 de 3 Wyze WVCR200s Bumper Replacement: étape 5, image 3 de 3
    • The small plastic connector holding the bumper in place should now be loose. Make sure it's disconnected.
    • Pull the bumper straight off of the vacuum.
Brandon Amado
Membre depuis le 03/20/23
411 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 5-5, Ramos Spring 2023 Membre de l'équipe UMass Dartmouth, Team 5-5, Ramos Spring 2023
UMASSD-RAMOS-S23S5G5
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 10
Total : 106
