Aller au contenu principal
X-Treme Tablet Generation 2 Motherboard Replacement
Ce dont vous avez besoin
  1. X-Treme Tablet Generation 2 Motherboard Replacement, Motherboard: étape 1, image 1 de 1
    • Remove the cover from the back of the tablet. Using the pick tool, pry the cover the case. Do this by starting in the upper corner, working around the edges until the cover unclips from the case.
  2. X-Treme Tablet Generation 2 Motherboard Replacement: étape 2, image 1 de 1
    Outil utilisé dans cette étape :
    Desoldering Pump
    $3.99
    J'achète
    • Find and detach all of the connections to the motherboard. Remove the connections while leaving the components in place from the battery, camera, ground wire, plastic connections at the charging port, and the 512MB DDR3 SDRAM.
    • Remove the connections using a soldering iron and desolder pump to remove the current soldered connections.
  3. X-Treme Tablet Generation 2 Motherboard Replacement: étape 3, image 1 de 2 X-Treme Tablet Generation 2 Motherboard Replacement: étape 3, image 2 de 2
    • Replacing the defective motherboard with a functional motherboard: Reattach the connections at the battery, camera, ground wire, plastic connections at the charging port, and the 512MB DDR3 SDRAM.
    • Reattach the connections by soldering them back onto the motherboard using a soldering iron.
Dalton Croslow
Membre depuis le 11/10/18
97 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S3-G3, Wilson Fall 2018 Membre de l'équipe IUPUI, Team S3-G3, Wilson Fall 2018
IUPUI-WILSON-F18S3G3
3 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 4
30 derniers jours : 4
Total : 210
