Aller au contenu principal
X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement
Ce dont vous avez besoin
  1. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement, Battery: étape 1, image 1 de 1
    • Unscrew the two 2.5mm Phillips #00 screws from the middle of the car.
    • Unclip the two clips to remove the battery cover.
  2. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: étape 2, image 1 de 1
    • Unplug the battery by pushing on the clip.
  3. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement, Underbody: étape 3, image 1 de 1
    • Unscrew the two 2.5mm Phillips #00 screws from each side
  4. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: étape 4, image 1 de 1
    • Remove the side skirt covers on each side of the car.
  5. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: étape 5, image 1 de 2 X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: étape 5, image 2 de 2
    • Lift up and remove the two side skirts.
  6. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: étape 6, image 1 de 1
    • Unscrew the two 2.5mm Phillips #00 screws from the front skirt of the car.
  7. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: étape 7, image 1 de 1
    • Lift the front part of the underbody and pull it out from the main underbody.
  8. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: étape 8, image 1 de 2 X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: étape 8, image 2 de 2
    • Unscrew the remaining seven 9mm Phillips #00 screws from the underbody of the car.
    • The second image shows a closer view of the rear three screws
  9. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: étape 9, image 1 de 2 X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: étape 9, image 2 de 2
    • Lift the main underbody from the shell of the car.
    • Lift up the body to expose the wiring and hardware underneath.
  10. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: étape 10, image 1 de 1
    • Remove the reflective sticker from the top of the body.
  11. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: étape 11, image 1 de 1
    • Unplug the wire connector.
  12. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement, Steering Column: étape 12, image 1 de 3 X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement, Steering Column: étape 12, image 2 de 3 X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement, Steering Column: étape 12, image 3 de 3
    • Unscrew the three 2.5mm Phillips #00 screws from the white steering column.
    • After removing the three screws, the steering column will pop out of position because of the springs underneath. To reassemble, put the springs back together as shown in picture #3.
  13. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement, Front Steering Motor: étape 13, image 1 de 1
    • Remove the three 1.6mm Phillips #000 screws from the black motor casing
  14. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: étape 14, image 1 de 1
    • Remove the front motor and its casing from the chassis of the car.
  15. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: étape 15, image 1 de 2 X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: étape 15, image 2 de 2
    • Remove the remaining three 1.6 mm Phillips #000 screws from the black motor casing
    • The second image shows the screws removed from the casing.
  16. X-street Lamborghini Murcielago LP670-4 SV Front Steering Motor Replacement: étape 16, image 1 de 1
    • Pull out the front motor, making sure to keep the gears intact
Trent Peterson
Membre depuis le 04/01/15
454 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 24-3, Lancaster Spring 2015 Membre de l'équipe Cal Poly, Team 24-3, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G3
3 membres
9 tutoriels rédigés
Un commentaire
How many volts is the battery?
DC2 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 10
Total : 540
