Aller au contenu principal
X230T RAM Replacement
Ce dont vous avez besoin
  1. X230T RAM Replacement, Removing the battery: étape 1, image 1 de 1
    • Start by removing the battery from the laptop. The battery should be removed to prevent damaging the motherboard when the RAM is installed and removed.
    • Slide the latch on the left to the left, and hold the other latch on the right to the right.
    • Slide out the battery, it should come out effortlessly.
  2. X230T RAM Replacement, Removing the RAM cover: étape 2, image 1 de 1
    • Undo the two screws that are circled, then, pry the RAM cover off by placing your finger nail or a spudger between the laptop and the RAM cover and puling up.
  3. X230T RAM Replacement, Removing RAM: étape 3, image 1 de 3 X230T RAM Replacement, Removing RAM: étape 3, image 2 de 3 X230T RAM Replacement, Removing RAM: étape 3, image 3 de 3
    • Remove the two clips from the RAM by pulling them slowly in the direction shown by the red arrows. When both clips are released, the RAM will lift up at a 45 degree angle (picture 2).
    • Once the RAM is at the angle as shown in picture 2, remove the RAM by pulling it out of the computer, as shown by the orange arrow.
    • If required, repeat the procedure for the other RAM module. The steps are the same.
  4. X230T RAM Replacement, Installing RAM: étape 4, image 1 de 3 X230T RAM Replacement, Installing RAM: étape 4, image 2 de 3 X230T RAM Replacement, Installing RAM: étape 4, image 3 de 3
    • To install the RAM, insert the new RAM with the notch on the RAM lining up to the notch on the slot. Slide the RAM in on a 45 degree angle as shown in picture 1.
    • Firmly push down the RAM until it is locked in place by the clips on either side. The clips will move around the RAM when the RAM is being inserted.
    • Put on the cover with the clips going in to the bottom edge of the cover first, then, tighten up the screws on the RAM cover.
    • Install the battery in to the computer, making sure the locking clips are engaged, and power the computer on.
    • Check the BIOS or your operating system to verify the RAM is working.
2 autres ont terminé cette réparation.
David Newberry
Membre depuis le 04/20/17
385 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 8
Total : 1,023
