Introduction
If you want more storage for games, or your hard drive is corrupted, then follow the steps below to replace your hard drive. You don't need any tools to replace your hard drive.
Outils
Aucun outil requis.
Pièces
  1. Orient your Xbox on the side where all the plugs are. Find the triangle-shaped release trigger. Slide the trigger and pull off the cover. Slide the trigger and pull off the cover.
    • Orient your Xbox on the side where all the plugs are. Find the triangle-shaped release trigger.
    • Slide the trigger and pull off the cover.
  2. %Livraison gratuite pour toute commande supérieure à 100,00 $US ou contenant un Pro Tech Toolkit !
    Parcourez notre boutique
  3. Find the tab coming out of the hard drive. Pull the tab, freeing the hard drive.  Keep pulling to get the hard drive out. Pull the tab, freeing the hard drive.  Keep pulling to get the hard drive out.
    • Find the tab coming out of the hard drive.
    • Pull the tab, freeing the hard drive. Keep pulling to get the hard drive out.
  4. Take your replacement hard drive and orient it so that it has the pull tab facing out.
    • Take your replacement hard drive and orient it so that it has the pull tab facing out.
    • Insert the new hard drive and push down until it clicks.
12 autre(s) ont terminé cette réparation.
Bryce
Membre depuis le 31/01/2014
1 016 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 2-11, Amido Winter 2014 Membre de l'équipe Cal Poly, Team 2-11, Amido Winter 2014
CPSU-AMIDO-W14S2G11
4 membres
11 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 56
Total : 8,521
