Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Xbox 360 HDD Replacement
Ce dont vous avez besoin
  1. Xbox 360 HDD Replacement, HDD: étape 1, image 1 de 3 Xbox 360 HDD Replacement, HDD: étape 1, image 2 de 3 Xbox 360 HDD Replacement, HDD: étape 1, image 3 de 3
    • Here it is. The standard 20GB HDD for the Xbox 360.
    • Notice the proprietary adapter. Inside is just a pretty standard 2.5" SATA drive...
    • I took these pictures as I was putting it back together, hence the Microsoft warranty sticker looking a little funny.
    • You may also notice the screw in the bottom left is partly out. This is because as I was replacing the screw before it, I broke my bit. I was using a 1/16" flathead bit (I don't have a T6 Torx) and used just a little too much torque and it snapped. I found another 1/16" bit to finish, but didn't get a pic.
    • If you have Torx bits/drivers, use them. They will work much better than the flatheads.
    Demander à FixBot
    Ajouter un commentaire
  2. Xbox 360 HDD Replacement: étape 2, image 1 de 1
    • Remove the Microsoft warranty sticker. I used my fingernail. Note: doing so voids the warranty for the drive, if it is still valid.
    • It only voids the warranty for the drive, not the console, being as their warranties are separate.
    • Proceed to remove the four T6 Torx screws.
    Demander à FixBot
  3. Xbox 360 HDD Replacement: étape 3, image 1 de 3 Xbox 360 HDD Replacement: étape 3, image 2 de 3 Xbox 360 HDD Replacement: étape 3, image 3 de 3
    • Holding the drive top up, gently pull the top half up from the bottom half. The back will rotate up as the front is connected by two plastic clips.
    • These clips are most easily undone by rotating the top enclosure to about 30º then lifting it up firmly.
    • Be careful to not let it jerk violently during separation. Once the top is removed, there isn't much of anything holding the latch mechanism in place. It would be a bummer to lose the spring, though getting the latch assembly back in place if it comes out is not too difficult, just don't lose the spring.
    Demander à FixBot
  4. Xbox 360 HDD Replacement: étape 4, image 1 de 1
    • Remove the four T10 Torx screws.
    • Slide the cover towards the back of the enclosure and remove. There is a small dot of lock-tite on each screw, fyi.
    Demander à FixBot
  5. Xbox 360 HDD Replacement: étape 5, image 1 de 2 Xbox 360 HDD Replacement: étape 5, image 2 de 2
    • Here are the innards in all their glory.
    • The four screws that held the cover on also held the drive in place, so just pull off the SATA connector and the drive is almost free.
    Demander à FixBot
  6. Xbox 360 HDD Replacement: étape 6, image 1 de 1
    • To actually get the drive out, you must bend the back of the plastic part of the bottom enclosure down a little bit. Doing so shouldn't break anything, just don't go overboard and bend it excessively.
    Demander à FixBot
  7. Xbox 360 HDD Replacement: étape 7, image 1 de 3 Xbox 360 HDD Replacement: étape 7, image 2 de 3 Xbox 360 HDD Replacement: étape 7, image 3 de 3
    • All the parts disassembled. The adapter cable will probably come out as it doesn't seem to be attached directly, but removing it would have required bending the metal enclosure and I didn't want to mess with that.
    • I thought it interesting to note that the drive runs at 5V 0.62A when the enclosure states 5V 1A. I wonder where the other 380mA are going.
    • Also interesting to note: this is a Seagate drive, while the 250GB drive upgrade I mention in the description requires a WD drive. If I understood correctly, this is because the software to format the drive to be recognized by your 360 is written for the WD firmware.
    Demander à FixBot
To reassemble your device, get your new hard drive and follow these instructions in reverse order.
67 autres ont terminé cette réparation.
R Trent
Membre depuis le 07/31/10
2 786 Réputation
1 tutoriel rédigé
6 commentaires de tutoriel
I happen to have an external HD enclosure (the original HD had a platter crash) that works perfectly to mount the XBox 360 HD to my PC for all sorts of uses, allowing for either USB or external SATA connectivity. :D
nonzerosum - Réponse Partager
Link to article seems to be down. Any mirrors? It woulb be much appreciated, Thanks
Chris Bersteinsson - Réponse Partager
Sounds and looks easy enough. But will replacing a 20 go drive with a 250 go drive now need any formatting or can I just plug it in and work?
James Mendez - Réponse Partager
Hola, buenas tardes, realice todos estos pasos y al instalar el disco no lo reconoce. Probe con otro disco y probe con el mismo que acababa de sacar y no lo reconoce. Enchufe el disco por medio de un cable al USB exterior y si lo reconoce.
Ahora supongo que es un problema en la coneccion del disco en su lugar original, puede ser en el cable o en el enchufe. Lo que quiero saber es si estoy bien orientado, o si existe algo que pase por alto y me esta generando este problema. Gracias
Pablo Farias - Réponse Partager
solo determitae marche di hardisk funzionano con la xbox 360 in piu devi installare il firmware o il software per farlo riconoscere e questo lo fai da pc ci sono molte guide in merito su youtube ciaooooooo
saxon sax - Réponse Partager
Nombre de vues :
Dernières 24 heures : 15
7 derniers jours : 132
30 derniers jours : 738
Total : 126,834
