Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Xbox 360 Optical Drive Replacement
Ce dont vous avez besoin
  1. Xbox 360 Optical Drive Replacement, Hard Drive: étape 1, image 1 de 2 Xbox 360 Optical Drive Replacement, Hard Drive: étape 1, image 2 de 2
    • Grasp the hard drive assembly and press the release button while lifting its front edge.
    • Remove the hard drive assembly from the top vent.
    Demander à FixBot
    Ajouter un commentaire
  2. Xbox 360 Optical Drive Replacement, Bottom Vent: étape 2, image 1 de 1
    Outil utilisé dans cette étape :
    Xbox 360 Opening Tool
    • Stand the console vertically with the bottom edge facing up.
    • Throughout the following opening procedure, the finger of an Xbox 360 opening tool can be used in place of a spudger.
    • Insert the flat end of a spudger or the edge of an Xbox 360 opening tool into the small gap at the front edge of the bottom vent.
    • Pry the front edge of the bottom vent away from the faceplate.
    Demander à FixBot
  3. Xbox 360 Optical Drive Replacement: étape 3, image 1 de 3 Xbox 360 Optical Drive Replacement: étape 3, image 2 de 3 Xbox 360 Optical Drive Replacement: étape 3, image 3 de 3
    • In the next few steps, you will use the tip of a spudger or the finger of an Xbox 360 opening tool to release the clips along the left and right sides of the bottom vent. Their locations are highlighted in red.
    • You will insert the tool into the holes molded into the white plastic side case pieces.
    Demander à FixBot
  4. Xbox 360 Optical Drive Replacement: étape 4, image 1 de 2 Xbox 360 Optical Drive Replacement: étape 4, image 2 de 2
    • To release the clips, work from the front edge of the bottom vent.
    • While slightly lifting the front edge of the bottom vent, use the tip of a spudger to push the clips closest to the front of the bottom vent towards the inside of the console.
    Demander à FixBot
  5. Xbox 360 Optical Drive Replacement: étape 5, image 1 de 2 Xbox 360 Optical Drive Replacement: étape 5, image 2 de 2
    • Repeat the same process to release the two center clips on the bottom vent.
    Demander à FixBot
  6. Xbox 360 Optical Drive Replacement: étape 6, image 1 de 2 Xbox 360 Optical Drive Replacement: étape 6, image 2 de 2
    • Use the tip of your spudger to release the clips on the bottom vent nearest the back of the Xbox.
    Demander à FixBot
  7. Xbox 360 Optical Drive Replacement: étape 7, image 1 de 1
    • Remove the bottom vent from the 360.
    Demander à FixBot
  8. Xbox 360 Optical Drive Replacement, Faceplate: étape 8, image 1 de 2 Xbox 360 Optical Drive Replacement, Faceplate: étape 8, image 2 de 2
    • Insert the flat edge of a spudger between the faceplate and the outer casing near the power button.
    • Run your spudger along the edge of the faceplate to release the clips securing it to the front of the console.
    • You may also accomplish this task by using the edge of the Xbox 360 opening tool, but it may scratch the plastic case.
    • Alternatively, you can use your hands to carefully pull the faceplate away from the Xbox.
    Demander à FixBot
  9. Xbox 360 Optical Drive Replacement: étape 9, image 1 de 1
    • Repeat the same motions as previously mentioned to release the left side of the faceplate.
    Demander à FixBot
  10. Xbox 360 Optical Drive Replacement: étape 10, image 1 de 1
    • Remove the faceplate from the front face of the console.
    Demander à FixBot
  11. Xbox 360 Optical Drive Replacement, Top Vent: étape 11, image 1 de 2 Xbox 360 Optical Drive Replacement, Top Vent: étape 11, image 2 de 2
    • Stand the console vertically with the top edge facing up.
    • The top vent is secured to the console via clips. The first two clips are located underneath the top vent closest to the faceplate, as shown in the pictures.
    Demander à FixBot
  12. Xbox 360 Optical Drive Replacement: étape 12, image 1 de 2 Xbox 360 Optical Drive Replacement: étape 12, image 2 de 2
    • Insert the flat end of a spudger into the small gaps previously mentioned to release the clips.
    • You may also use the long finger of an Xbox 360 opening tool to accomplish this task.
    Demander à FixBot
  13. Xbox 360 Optical Drive Replacement: étape 13, image 1 de 3 Xbox 360 Optical Drive Replacement: étape 13, image 2 de 3 Xbox 360 Optical Drive Replacement: étape 13, image 3 de 3
    • In the next few steps, you will use the tip of a spudger or the finger of an Xbox 360 opening tool to release the clips along the left and right sides of the top vent. Their locations are highlighted in red.
    Demander à FixBot
  14. Xbox 360 Optical Drive Replacement: étape 14, image 1 de 2 Xbox 360 Optical Drive Replacement: étape 14, image 2 de 2
    • To release the clips, work from the middle of the top vent.
    • While slightly lifting the front edge of the top vent, use the tip of a spudger to push the clips closest to the center of the top vent towards the inside of the console.
    Demander à FixBot
  15. Xbox 360 Optical Drive Replacement: étape 15, image 1 de 1
    • Use the tip of your spudger to release the clip on the top vent nearest the back of the Xbox's upper case.
    Demander à FixBot
  16. Xbox 360 Optical Drive Replacement: étape 16, image 1 de 2 Xbox 360 Optical Drive Replacement: étape 16, image 2 de 2
    • The last clip is hidden underneath the rubber foot nearest the back of the console.
    • Use the tip of your spudger to release the clip on the top vent nearest the back of the Xbox.
    • Remove the top vent from the 360.
    Demander à FixBot
  17. Xbox 360 Optical Drive Replacement, Lower Case: étape 17, image 1 de 1
    • Stand the console vertically with the top edge facing down.
    • Carefully peel the warranty sticker off the console.
    Demander à FixBot
  18. Xbox 360 Optical Drive Replacement: étape 18, image 1 de 3 Xbox 360 Optical Drive Replacement: étape 18, image 2 de 3 Xbox 360 Optical Drive Replacement: étape 18, image 3 de 3
    • The upper and lower cases are attached via several latches, located in the front and back of the console. These latches must be disengaged to separate the upper case from the console.
    • Use the flat end of a spudger to release the following latches:
    • Above the front-facing USB ports.
    • Beneath the front-facing USB ports.
    • Above the Memory Unit slots.
    Demander à FixBot
  19. Xbox 360 Optical Drive Replacement: étape 19, image 1 de 1
    • Insert the flat end of a spudger and pry upwards to release the last remaining latch located above the eject button.
    Demander à FixBot
  20. Xbox 360 Optical Drive Replacement: étape 20, image 1 de 1
    • Slightly lift the front portion of the lower case to ensure that the latches in the front have been completely released.
    Demander à FixBot
  21. Xbox 360 Optical Drive Replacement: étape 21, image 1 de 2 Xbox 360 Optical Drive Replacement: étape 21, image 2 de 2
    • The upper and lower cases are held together by seven release latches located on the back of the console. Their locations are highlighted in red.
    Demander à FixBot
  22. Xbox 360 Optical Drive Replacement: étape 22, image 1 de 3 Xbox 360 Optical Drive Replacement: étape 22, image 2 de 3 Xbox 360 Optical Drive Replacement: étape 22, image 3 de 3
    • Press the Xbox 360 opening tool down into the clips securing the lower case to the upper case near the I/O ports.
    • While pressing down on the tool, push the lower and upper cases apart to separate the retaining clips.
    Demander à FixBot
  23. Xbox 360 Optical Drive Replacement: étape 23, image 1 de 2 Xbox 360 Optical Drive Replacement: étape 23, image 2 de 2
    • While pushing the upper and lower cases apart, use the tip of a spudger or the finger of an Xbox 360 opening tool to push the long clip highlighted in red toward the center of the 360.
    • The clip should release, leaving the clips near the power connector as the only thing holding the upper and lower cases together.
    Demander à FixBot
  24. Xbox 360 Optical Drive Replacement: étape 24, image 1 de 1
    • Press the Xbox 360 opening tool down into the two remaining clips near the power connector.
    • Push the upper and lower cases apart to fully release the retaining clips.
    Demander à FixBot
  25. Xbox 360 Optical Drive Replacement: étape 25, image 1 de 1
    • Orient the console so that the front portion is facing downwards.
    • Grasp the back portion of the lower case and lift it upwards to separate it from the console.
    • Be careful not to excessively bend the lower case near the power plug, as it can crack easily.
    Demander à FixBot
  26. Xbox 360 Optical Drive Replacement, Eject Button: étape 26, image 1 de 2 Xbox 360 Optical Drive Replacement, Eject Button: étape 26, image 2 de 2
    • Use the tip of a spudger to release the clip securing the eject button to the metal casing.
    • Insert the flat end of a spudger between the eject button and the optical drive.
    • Pry the eject button off its retaining posts and remove it from the 360.
    • This can also be accomplished using an Xbox 360 opening tool.
    Demander à FixBot
  27. Xbox 360 Optical Drive Replacement, Upper Case: étape 27, image 1 de 1
    • Remove the six silver 64 mm T10 Torx screws securing the upper case to the metal casing.
    Demander à FixBot
  28. Xbox 360 Optical Drive Replacement: étape 28, image 1 de 1
    • Orient the console so that the upper case is facing upwards.
    • Lift the upper case straight up and remove it from the console.
    Demander à FixBot
  29. Xbox 360 Optical Drive Replacement, Optical Drive: étape 29, image 1 de 1
    • Peel the silver tape securing the optical drive to the metal casing.
    Demander à FixBot
  30. Xbox 360 Optical Drive Replacement: étape 30, image 1 de 1
    • Slightly lift the optical drive upwards to gain clearance to disconnect the SATA and power connectors located on the backside of the optical drive.
    • Don't try to completely remove the optical drive just yet. Two cables still connect it to the motherboard.
    Demander à FixBot
  31. Xbox 360 Optical Drive Replacement: étape 31, image 1 de 2 Xbox 360 Optical Drive Replacement: étape 31, image 2 de 2
    • Grab the power connector by its cables and pull it straight out of its socket on the optical drive.
    • Disconnect the SATA data connector from its socket on the optical drive by pulling it straight away.
    Demander à FixBot
  32. Xbox 360 Optical Drive Replacement: étape 32, image 1 de 1
    • Lift the optical drive assembly out of the metal casing.
    Demander à FixBot
  33. Xbox 360 Optical Drive Replacement, Xbox 360 Optical Drive Replacement: étape 33, image 1 de 2 Xbox 360 Optical Drive Replacement, Xbox 360 Optical Drive Replacement: étape 33, image 2 de 2
    • While pressing the optical drive cover toward the top face of the optical drive, use the flat end of a spudger to release the two retaining clips on the underside of the cover.
    Demander à FixBot
  34. Xbox 360 Optical Drive Replacement: étape 34, image 1 de 1
    • Remove the optical drive cover.
    • Optical drive remains.
    Demander à FixBot
238 autres ont terminé cette réparation.
25 commentaires de tutoriel
who knows xbox360 can use desktop drives?We have all kinds of drives,but i am not sure if it is fit for xbox360.
Thanks
Rex Yang - Réponse Partager
That has nothing to do with this guide. If you have any question regarding this equipment, go to the answer section.
oldturkey03 - Réponse Partager
General comment, you make no mention of removing the PCB from the DVD drive if it's being replaced. Any particular reason for that?
Pete B - Réponse Partager
Very easy to follow, got my drive fixed...thanks!
Brian Davis - Réponse Partager
" Replacing a defective optical drive with a replacement optical drive does not work. The replacement will have a different DVD drive key, which the game console will not accept."
Not entirely accurate, that statement.
Having fixed a PS3 blu-ray drive by following the excellent guide on here, tried the same technique.
I had a bad drive in my xbox, and I replaced it with a new drive (of the same type). I took the daughter-board from the faulty drive and transplanted it to the good drive. It involved stripping down both drives, disconnecting 2 ribbon cables and unsoldering about 8 wires, transplanting the daughter-board - and resoldering the wires. Then reassembling. It worked for me, anyway.
Dave - Réponse Partager
Nombre de vues :
Dernières 24 heures : 30
7 derniers jours : 185
30 derniers jours : 948
Total : 421,629
