Aller au contenu principal
Xbox 360 S Fan Replacement
Ce dont vous avez besoin
  1. Xbox 360 S Fan Replacement, Top Panel: étape 1, image 1 de 1
    • In the following steps, you will remove the top vent, secured to the top panel by the thirteen clips shown.
    • Take care when removing the fan vent not to break any of the plastic clips.
  2. Xbox 360 S Fan Replacement: étape 2, image 1 de 2 Xbox 360 S Fan Replacement: étape 2, image 2 de 2
    • Orient the console so that the words "XBOX 360" on the sides are right-side up, and the faceplate is facing to the left.
    • Insert a metal spudger between the top vent and the top bezel near the rear of the Xbox.
    • Rotate the spudger away from the console, prying the edge of the fan vent up until the two plastic clips come free.
    • Be sure to rotate the spudger far enough so that the plastic clips clear the silver rim of the top bezel.
  3. Xbox 360 S Fan Replacement: étape 3, image 1 de 3 Xbox 360 S Fan Replacement: étape 3, image 2 de 3 Xbox 360 S Fan Replacement: étape 3, image 3 de 3
    • Insert a metal spudger between the fan vent and top bezel along the left side of the console.
    • In the same manner described above, begin prying the left side of the top vent away from the top bezel.
    • Continue prying along the left side of the device, freeing all the clips on that side.
  4. Xbox 360 S Fan Replacement: étape 4, image 1 de 2 Xbox 360 S Fan Replacement: étape 4, image 2 de 2
    • Lift the fan vent up from the freed left side to disengage the clips along the right side.
    • Remove the entire fan vent.
  5. Xbox 360 S Fan Replacement: étape 5, image 1 de 2 Xbox 360 S Fan Replacement: étape 5, image 2 de 2
    • In the following steps, you will be releasing the six clips highlighted in red.
    • Each clip can be undone by inserting a metal spudger underneath the bottom edge of the clip. Once underneath the bottom edge, simply prying away from the console will free the clip.
  6. Xbox 360 S Fan Replacement: étape 6, image 1 de 2 Xbox 360 S Fan Replacement: étape 6, image 2 de 2
    • Orient the console so that the left case is facing toward you and the faceplate is facing toward the right.
    • Insert a metal spudger through the front-most slit on the left edge of the top bezel and between the bottom edge of the clip and the left case, as described above.
    • Simultaneously rotate the spudger away from the console and pull up on the top bezel to free the clip.
    • You will hear a "pop" signifying that the clip cleared its catch.
  7. Xbox 360 S Fan Replacement: étape 7, image 1 de 2 Xbox 360 S Fan Replacement: étape 7, image 2 de 2
    • Using the same method described above, free the two remaining clips along the left edge of the top bezel.
  8. Xbox 360 S Fan Replacement: étape 8, image 1 de 1
    • Grab the entire top panel with your hands, lift up the entire left edge high enough to rest the separated clips on top of the left case.
    • You may have to go back with a spudger and undo any clips that have re-attached.
    • The top panel will not come free of the console yet.
  9. Xbox 360 S Fan Replacement: étape 9, image 1 de 2 Xbox 360 S Fan Replacement: étape 9, image 2 de 2
    • Rotate the console so that the rear of the Xbox 360 S is facing to the right, and the right case is facing you.
    • Insert a metal spudger through the rear-most slit on the right edge of the top bezel and between the bottom edge of the clip and the right case.
    • While lifting up on the top bezel with your fingers, rotate the spudger away from the console to free the clip.
  10. Xbox 360 S Fan Replacement: étape 10, image 1 de 2 Xbox 360 S Fan Replacement: étape 10, image 2 de 2
    • In the same manner as described in the previous steps, release the middle and front clips along the right edge of the top panel.
  11. Xbox 360 S Fan Replacement: étape 11, image 1 de 1
    • Lift the top panel off the device.
    • You may have to go back with a spudger and undo any clips that have re-attached to the console.
  12. Xbox 360 S Fan Replacement, Hard Drive: étape 12, image 1 de 3 Xbox 360 S Fan Replacement, Hard Drive: étape 12, image 2 de 3 Xbox 360 S Fan Replacement, Hard Drive: étape 12, image 3 de 3
    • Orient the Xbox 360 S so that the bottom of the console is facing toward you.
    • Push the latch holding down the hard drive cover to the left.
    • Pull the hard drive cover away from the console.
  13. Xbox 360 S Fan Replacement: étape 13, image 1 de 3 Xbox 360 S Fan Replacement: étape 13, image 2 de 3 Xbox 360 S Fan Replacement: étape 13, image 3 de 3
    • Firmly grasp the fabric tab labeled with the size of the hard drive (e.g. "250 GB") attached to the hard drive.
    • Pull the hard drive straight out of the console.
    • The fabric tab is attached to a catch further inside the hard drive housing. It will take some force to pull the hard drive out.
  14. Xbox 360 S Fan Replacement, Bottom Panel: étape 14, image 1 de 1
    • In the following steps, you will remove the bottom vent.
    • It is attached to the bottom panel by the seven clips shown.
  15. Xbox 360 S Fan Replacement: étape 15, image 1 de 2 Xbox 360 S Fan Replacement: étape 15, image 2 de 2
    • Orient the Xbox 360 S so that the hard drive port is facing up and the faceplate is facing to the left.
    • Insert a metal spudger between the black bottom vent and the silver rim of the bottom bezel, in the rear right corner of the vent.
    • Rotate the spudger away from the console, prying the vent up from the bottom bezel.
    • Be sure to rotate the spudger far enough so that the clips on the vent are lifted past the silver rim of the bottom bezel.
  16. Xbox 360 S Fan Replacement: étape 16, image 1 de 3 Xbox 360 S Fan Replacement: étape 16, image 2 de 3 Xbox 360 S Fan Replacement: étape 16, image 3 de 3
    • In the same manner as described above, pry the two remaining clips on the bottom right edge.
    • All of the clips along both the right and front edge should now be free. If other clips have come undone as well, that is fine.
  17. Xbox 360 S Fan Replacement: étape 17, image 1 de 2 Xbox 360 S Fan Replacement: étape 17, image 2 de 2
    • Remove the bottom vent by lifting it away from the bottom bezel.
  18. Xbox 360 S Fan Replacement: étape 18, image 1 de 2 Xbox 360 S Fan Replacement: étape 18, image 2 de 2
    • In the following steps, you will remove the bottom bezel, which is attached to the rest of the console by the six clips shown.
    • The clips shown in red can be detached by inserting a metal spudger underneath the bottom edge of the clip. Once underneath the bottom edge, simply prying away from the console will free the clip.
  19. Xbox 360 S Fan Replacement: étape 19, image 1 de 2 Xbox 360 S Fan Replacement: étape 19, image 2 de 2
    • Insert a metal spudger through the slit near the rear left corner of the bottom bezel.
    • Rotate the spudger away from the device while lifting the rear bezel up with the other hand.
    • You may hear a "pop" signifying the clip has cleared its catch.
  20. Xbox 360 S Fan Replacement: étape 20, image 1 de 2 Xbox 360 S Fan Replacement: étape 20, image 2 de 2
    • Insert a metal spudger through the left middle slit of the bottom bezel, and between the bottom edge of the clip and the left case.
    • Simultaneously pull the bottom bezel up and rotate the spudger away from the console to free the clip.
    • In a similar fashion, free the clip at the front of the bottom bezel's left edge.
    • The entire left side of the bottom bezel should now be free.
  21. Xbox 360 S Fan Replacement: étape 21, image 1 de 2 Xbox 360 S Fan Replacement: étape 21, image 2 de 2
    • Turn the console around so that the faceplate is facing to the right and the right case is facing toward you.
    • Insert the spudger into the rear-most slit on the right edge of the bottom bezel, and wedge it behind the clip by pushing the spudger down while pushing the tip of the spudger against the right case.
    • Simultaneously release the clip and pull the bottom bezel up.
    • This clip is especially hard to remove. Some force will be required to insert the spudger correctly.
  22. Xbox 360 S Fan Replacement: étape 22, image 1 de 1
    • This clip does not have a slit in the bezel to guide you. You can locate the clip by looking under the bezel near the hard drive slot.
    • Insert a spudger between the silver rim and bottom bezel directly above the clip shown.
    • Release the clip while pulling up on the bottom bezel.
  23. Xbox 360 S Fan Replacement: étape 23, image 1 de 2 Xbox 360 S Fan Replacement: étape 23, image 2 de 2
    • This clip is smaller than the others and should not be removed from above like the others.
    • Lift the left edge of the bottom bezel up enough to gain clearance.
    • Insert a metal spudger behind the left edge of the last clip, and push the clip away from the right case.
  24. Xbox 360 S Fan Replacement, Left Case: étape 24, image 1 de 1
    • Opening your Xbox 360 any further will require breaking or removing the warranty sticker on the outer case. Your Microsoft warranty for any components not directly attached to the logic board will likely be voided by removing this seal.
  25. Xbox 360 S Fan Replacement: étape 25, image 1 de 2 Xbox 360 S Fan Replacement: étape 25, image 2 de 2
    • Orient the console right-side up, with the faceplate facing toward you.
    • Locate the two clips connecting the right and left case along the top edge of the console, behind the Wi-Fi card.
    • While pushing the left and right case away from each other with one hand, pry the clips away from the case with a metal spudger.
  26. Xbox 360 S Fan Replacement: étape 26, image 1 de 2 Xbox 360 S Fan Replacement: étape 26, image 2 de 2
    • Continue to hold the two cases apart to prevent the clips reattaching.
    • Insert a spudger between the right and left cases to hold them separate while you work elsewhere.
  27. Xbox 360 S Fan Replacement: étape 27, image 1 de 2 Xbox 360 S Fan Replacement: étape 27, image 2 de 2
    • Flip the Xbox over so the faceplate is facing left, and the left case is facing toward you.
    • While pushing the left and right cases apart with one hand, free one clip located beside the hard drive slot.
  28. Xbox 360 S Fan Replacement: étape 28, image 1 de 2 Xbox 360 S Fan Replacement: étape 28, image 2 de 2
    • Continue to hold the cases apart to prevent the clips from reattaching.
    • Place another spudger between the left and right cases directly below the clip.
  29. Xbox 360 S Fan Replacement: étape 29, image 1 de 3 Xbox 360 S Fan Replacement: étape 29, image 2 de 3 Xbox 360 S Fan Replacement: étape 29, image 3 de 3
    • Insert the flat edge of a metal spudger between the left and right cases where the warranty sticker used to be.
    • Pry the left case upwards to form a gap between the two cases, and slide the spudger in toward the left case.
    • Rotate the spudger upward to release the last clip.
    • The spudgers holding the top and bottom clips apart may be removed.
  30. Xbox 360 S Fan Replacement: étape 30, image 1 de 2 Xbox 360 S Fan Replacement: étape 30, image 2 de 2
    • Release one clip in the front left corner of the top edge securing the left case to the faceplate.
  31. Xbox 360 S Fan Replacement: étape 31, image 1 de 2 Xbox 360 S Fan Replacement: étape 31, image 2 de 2
    • Flip the console over so the bottom is facing upward.
    • Release one clip in the front left corner of the bottom edge securing the left case to the faceplate.
    • Rotate the left case away from the device to release the last two inner clips.
    • Remove the left case.
  32. Xbox 360 S Fan Replacement, Faceplate: étape 32, image 1 de 2 Xbox 360 S Fan Replacement, Faceplate: étape 32, image 2 de 2
    • Orient the console right-side-up, with the faceplate facing forward.
    • Release the clip near the front right corner of the top edge securing the right case to the faceplate.
  33. Xbox 360 S Fan Replacement: étape 33, image 1 de 1
    • Turn the console over, so that the bottom is facing upward, and the faceplate is facing forward.
    • Release the clip in the bottom right corner of the top edge securing the right case to the front case.
  34. Xbox 360 S Fan Replacement: étape 34, image 1 de 2 Xbox 360 S Fan Replacement: étape 34, image 2 de 2
    • Lift the left edge of the faceplate upward to release the last two clips securing the faceplate to the right case.
    • Detach the faceplate from the rest of the device.
    • The faceplate is still attached to the console by a thin ribbon cable. Do not attempt to completely remove the faceplate yet.
  35. Xbox 360 S Fan Replacement: étape 35, image 1 de 3 Xbox 360 S Fan Replacement: étape 35, image 2 de 3 Xbox 360 S Fan Replacement: étape 35, image 3 de 3
    • Using a spudger or fingernail, lift the clear blue tab away from the connector.
    • Slide the locking tab on the power switch board cable connector toward the top of the console.
    • The locking tab will only move about 2 mm.
    • Pull the power switch cable straight out of the connector.
    • The faceplate is now free of the rest of the console.
  36. Xbox 360 S Fan Replacement, RF Module: étape 36, image 1 de 1
    • Remove the two 5.6 mm T8 Torx screws securing the RF module to the metal case.
  37. Xbox 360 S Fan Replacement: étape 37, image 1 de 2 Xbox 360 S Fan Replacement: étape 37, image 2 de 2
    • The RF module is still connected to the Xbox by a large USB-type connector.
    • Pull the board directly away from the Xbox to remove it.
  38. Xbox 360 S Fan Replacement, Wi-Fi Board: étape 38, image 1 de 3 Xbox 360 S Fan Replacement, Wi-Fi Board: étape 38, image 2 de 3 Xbox 360 S Fan Replacement, Wi-Fi Board: étape 38, image 3 de 3
    • Remove the single T10 Torx screw holding in the wireless card.
    • Pull the Wi-Fi Board out of the console.
  39. Xbox 360 S Fan Replacement, Right Case: étape 39, image 1 de 1
    • This is the terminal point if you ever want to send your Xbox back to Microsoft for repair.
    • Remove the large white warranty sticker from the metal frame to expose a screw.
  40. Xbox 360 S Fan Replacement: étape 40, image 1 de 1
    • Remove the five 55.5 mm T10 Torx screws securing the right case to the metal frame.
  41. Xbox 360 S Fan Replacement: étape 41, image 1 de 1
    • Turn the Xbox over so the right case is facing up.
    • Lift the right case off by its metal framework.
  42. Xbox 360 S Fan Replacement, Optical Drive: étape 42, image 1 de 2 Xbox 360 S Fan Replacement, Optical Drive: étape 42, image 2 de 2
    • Disconnect the optical drive data cable from the back of the optical drive.
    • Disconnect the power cable from the back of the optical drive.
  43. Xbox 360 S Fan Replacement: étape 43, image 1 de 1
    • Lift the optical drive out of the Xbox.
  44. Xbox 360 S Fan Replacement, Hard Drive Bracket: étape 44, image 1 de 1
    • Turn the console over so that the metal case is facing up.
    • Remove the single 11.3 mm gold T10 Torx screw from the hole marked "G."
  45. Xbox 360 S Fan Replacement: étape 45, image 1 de 2 Xbox 360 S Fan Replacement: étape 45, image 2 de 2
    • Lift the fan duct off the fan.
    • There is a locator peg underneath the fan duct (top right corner of the fan duct as viewed in the pictures). When reinstalling look down the screw hole to aid alignment.
  46. Xbox 360 S Fan Replacement: étape 46, image 1 de 2 Xbox 360 S Fan Replacement: étape 46, image 2 de 2
    • Remove the single 9.2 mm T10 Torx screw securing the hard drive cable connector to the plastic bracket.
    • Lift the hard drive cable connector off the hard drive bracket.
  47. Xbox 360 S Fan Replacement: étape 47, image 1 de 1
    • Remove the 11.3 mm T10 Torx screw holding the hard drive bracket to the metal frame, near the DC-In port.
  48. Xbox 360 S Fan Replacement: étape 48, image 1 de 1
    • Lift the hard drive bracket out of the metal frame.
  49. Xbox 360 S Fan Replacement, Fan: étape 49, image 1 de 1
    • Disconnect the fan cable by pulling its connector off the logic board.
  50. Xbox 360 S Fan Replacement: étape 50, image 1 de 3 Xbox 360 S Fan Replacement: étape 50, image 2 de 3 Xbox 360 S Fan Replacement: étape 50, image 3 de 3
    • Unscrew the two 11.7 mm Phillips screws securing the fan to the heat sink in the bottom right and top left corners of the fan.
    • Remove the fan from the logic board assembly.
101 autres ont terminé cette réparation.
Matthew Newsom
Membre depuis le 01/05/10
39 524 Réputation
67 tutoriels rédigés
7 commentaires
Do I need to buy a new fan, or does this tutorial basically use a method of cleaning things out to fix the fan?
Luke Beeler - Réponse
A bit late I know, but if you’re getting this deep into the system, put in a new fan.
This tutorial was perfect.
Thank you Mr. Newsom!
David Adamski - Réponse
Loved your instruction so easy to follow compared to all the other DIY sites I have visited. Thank you so much!!!!! Now do you have one on how to download and use torrent files?
jim7858 - Réponse
what wrong with x360 s
Andrecious Gamble - Réponse
So could I water cool this thing?
evan hardison - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 20
7 derniers jours : 117
30 derniers jours : 458
Total : 111,494
