Introduction
Wireless internet not working? Replace the wireless card to get back on Xbox Live today.
Outils
Pièces
In the following steps, you will remove the top vent, secured to the top panel by the thirteen clips shown.
Orient the console so that the words "XBOX 360" on the sides are right-side up, and the faceplate is facing to the left.
Insert a metal spudger between the top vent and the top bezel near the rear of the Xbox.
Rotate the spudger away from the console, prying the edge of the fan vent up until the two plastic clips come free.
Insert a metal spudger between the fan vent and top bezel along the left side of the console.
In the same manner described above, begin prying the left side of the top vent away from the top bezel.
Continue prying along the left side of the device, freeing all the clips on that side.
Rotate the console so that the rear of the Xbox 360 S is facing to the right, and the right case is facing you.
Insert a metal spudger through the rear-most slit on the right edge of the top bezel and between the bottom edge of the clip and the right case.
While lifting up on the top bezel with your fingers, rotate the spudger away from the console to free the clip.
Remove the single T10 Torx screw holding in the wireless card.
Pull the Wi-Fi board out of the console.
32 autres ont terminé cette réparation.
3 commentaires
My Slim came without the wifi board, and subsequently without the holding screw.
Anyone know the thread, size, or depth of a replacement screw I could use to hold the replacement in? It seems like it won't go anywhere with the pseudo-USB connector in place, but I'd like to be positive.
Any help would be appreciated!
Tuve ese mismo problema. Fui a una tienda y el técnico tuvo que quitarle la tarjeta de WiFi a otro xbox porque no hay repuesto
Worth noting.. Before you purchase a new wifi card, try taking it out and reseating it. Just had to do that with mine when the wifi suddenly stopped working. Once I pulled the card and put it back in, it worked beautifully.
Also, for clarification, you are opening the side OPPOSITE the side with the hard drive.
