Aller au contenu principal
Xbox 360 S Wi-Fi Board Replacement
Ce dont vous avez besoin
  1. Xbox 360 S Wi-Fi Board Replacement, Top Panel: étape 1, image 1 de 1
    • In the following steps, you will remove the top vent, secured to the top panel by the thirteen clips shown.
    • Take care when removing the fan vent not to break any of the plastic clips.
  2. Xbox 360 S Wi-Fi Board Replacement: étape 2, image 1 de 2 Xbox 360 S Wi-Fi Board Replacement: étape 2, image 2 de 2
    • Orient the console so that the words "XBOX 360" on the sides are right-side up, and the faceplate is facing to the left.
    • Insert a metal spudger between the top vent and the top bezel near the rear of the Xbox.
    • Rotate the spudger away from the console, prying the edge of the fan vent up until the two plastic clips come free.
    • Be sure to rotate the spudger far enough so that the plastic clips clear the silver rim of the top bezel.
    Whoever gave that tool the name “spudger” needs to be shot in the face.
    Richard - Réponse
    This step is and the others following are to rough and not needed, simply put smth in between the lamellar and push it up with littlebit pressure thats better for the plastic parts.
    TheSupport - Réponse
  3. Xbox 360 S Wi-Fi Board Replacement: étape 3, image 1 de 3 Xbox 360 S Wi-Fi Board Replacement: étape 3, image 2 de 3 Xbox 360 S Wi-Fi Board Replacement: étape 3, image 3 de 3
    • Insert a metal spudger between the fan vent and top bezel along the left side of the console.
    • In the same manner described above, begin prying the left side of the top vent away from the top bezel.
    • Continue prying along the left side of the device, freeing all the clips on that side.
  4. Xbox 360 S Wi-Fi Board Replacement: étape 4, image 1 de 2 Xbox 360 S Wi-Fi Board Replacement: étape 4, image 2 de 2
    • Lift the fan vent up from the freed left side to disengage the clips along the right side.
    • Remove the entire fan vent.
  5. Xbox 360 S Wi-Fi Board Replacement: étape 5, image 1 de 2 Xbox 360 S Wi-Fi Board Replacement: étape 5, image 2 de 2
    • In the following steps, you will be releasing the six clips highlighted in red.
    • Each clip can be undone by inserting a metal spudger underneath the bottom edge of the clip. Once underneath the bottom edge, simply prying away from the console will free the clip.
    see the red boxes specially in image
    Restrict - Réponse
  6. Xbox 360 S Wi-Fi Board Replacement: étape 6, image 1 de 2 Xbox 360 S Wi-Fi Board Replacement: étape 6, image 2 de 2
    • Orient the console so that the left case is facing toward you and the faceplate is facing toward the right.
    • Insert a metal spudger through the front-most slit on the left edge of the top bezel and between the bottom edge of the clip and the left case, as described above.
    • Simultaneously rotate the spudger away from the console and pull up on the top bezel to free the clip.
    • You will hear a "pop" signifying that the clip cleared its catch.
    So I got the fan filter thing off, but the black edge plate thing isn't coming off. All I did was warp my flathead screwdriver and scratch the console.
    HumidTater - Réponse
  7. Xbox 360 S Wi-Fi Board Replacement: étape 7, image 1 de 2 Xbox 360 S Wi-Fi Board Replacement: étape 7, image 2 de 2
    • Using the same method described above, free the two remaining clips along the left edge of the top bezel.
  8. Xbox 360 S Wi-Fi Board Replacement: étape 8, image 1 de 1
    • Grab the entire top panel with your hands, lift up the entire left edge high enough to rest the separated clips on top of the left case.
    • You may have to go back with a spudger and undo any clips that have re-attached.
    • The top panel will not come free of the console yet.
  9. Xbox 360 S Wi-Fi Board Replacement: étape 9, image 1 de 2 Xbox 360 S Wi-Fi Board Replacement: étape 9, image 2 de 2
    • Rotate the console so that the rear of the Xbox 360 S is facing to the right, and the right case is facing you.
    • Insert a metal spudger through the rear-most slit on the right edge of the top bezel and between the bottom edge of the clip and the right case.
    • While lifting up on the top bezel with your fingers, rotate the spudger away from the console to free the clip.
  10. Xbox 360 S Wi-Fi Board Replacement: étape 10, image 1 de 2 Xbox 360 S Wi-Fi Board Replacement: étape 10, image 2 de 2
    • In the same manner as described in the previous steps, release the middle and front clips along the right edge of the top panel.
  11. Xbox 360 S Wi-Fi Board Replacement: étape 11, image 1 de 1
    • Lift the top panel off the device.
    • You may have to go back with a spudger and undo any clips that have re-attached to the console.
  12. Xbox 360 S Wi-Fi Board Replacement, Wi-Fi Board: étape 12, image 1 de 3 Xbox 360 S Wi-Fi Board Replacement, Wi-Fi Board: étape 12, image 2 de 3 Xbox 360 S Wi-Fi Board Replacement, Wi-Fi Board: étape 12, image 3 de 3
    • Remove the single T10 Torx screw holding in the wireless card.
    • Pull the Wi-Fi board out of the console.
37 autres ont terminé cette réparation.
Brett Hartt
Membre depuis le 04/12/10
127 897 Réputation
143 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
16 817 tutoriels rédigés
4 commentaires
My Slim came without the wifi board, and subsequently without the holding screw.
Anyone know the thread, size, or depth of a replacement screw I could use to hold the replacement in? It seems like it won't go anywhere with the pseudo-USB connector in place, but I'd like to be positive.
Any help would be appreciated!
mattinnihon - Réponse
Tuve ese mismo problema. Fui a una tienda y el técnico tuvo que quitarle la tarjeta de WiFi a otro xbox porque no hay repuesto
andreshgarcia20 - Réponse
Worth noting.. Before you purchase a new wifi card, try taking it out and reseating it. Just had to do that with mine when the wifi suddenly stopped working. Once I pulled the card and put it back in, it worked beautifully.
Also, for clarification, you are opening the side OPPOSITE the side with the hard drive.
sarncadrill - Réponse
Is it possible to replace it a newer, updated, improved WiFi card that is faster?
NoraTheSuccubus - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 7
7 derniers jours : 61
30 derniers jours : 190
Total : 55,775
