Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Xbox 360 Wireless Controller 3D Analog Sensor Replacement
Tutoriel Archivé
Ce tutoriel est conservé uniquement à des fins de suivis historiques. Utilisez la version actuelle du tutoriel pour effectuer votre réparation.
Ce dont vous avez besoin
  1. Xbox 360 Wireless Controller 3D Analog Sensor Replacement, Battery: étape 1, image 1 de 2 Xbox 360 Wireless Controller 3D Analog Sensor Replacement, Battery: étape 1, image 2 de 2
    • Depress the battery release button on the top of the controller.
    • Remove the battery holder from the controller.
    • The standard option for Xbox 360 Wireless Controllers Battery Packs is AA batteries. A rechargeable battery is also available, but both battery options are removed from the controller in the same way.
  2. Xbox 360 Wireless Controller 3D Analog Sensor Replacement, Rear Case: étape 2, image 1 de 1
    Outil utilisé dans cette étape :
    • Use a pair of tweezers to peel the barcode sticker from the battery compartment.
  3. Xbox 360 Wireless Controller 3D Analog Sensor Replacement: étape 3, image 1 de 1
    • Remove the seven 9.3 mm T8 Security Torx screws securing the rear case to the front case.
  4. Xbox 360 Wireless Controller 3D Analog Sensor Replacement: étape 4, image 1 de 2 Xbox 360 Wireless Controller 3D Analog Sensor Replacement: étape 4, image 2 de 2
    Spudger
    $2.99
    • Insert a Spudger between the front and rear cases along the left edge of the controller.
    • Rotate the spudger toward the front of the controller, prying the two cases apart.
  5. Xbox 360 Wireless Controller 3D Analog Sensor Replacement: étape 5, image 1 de 2 Xbox 360 Wireless Controller 3D Analog Sensor Replacement: étape 5, image 2 de 2
    • Insert a spudger between the front and rear cases, near the headphone jack.
    • Rotate the spudger toward the front of the controller to pry the two cases apart.
  6. Xbox 360 Wireless Controller 3D Analog Sensor Replacement: étape 6, image 1 de 2 Xbox 360 Wireless Controller 3D Analog Sensor Replacement: étape 6, image 2 de 2
    • Grasp the controller by the battery compartment and the headphone jack.
    • Lift the battery compartment away from the headphone jack, separating the rear case from the front case and logic board.
    • The battery contact springs are held in place by slots in the battery housing in the rear case. Be sure to realign them properly during reassembly.
  7. Xbox 360 Wireless Controller 3D Analog Sensor Replacement, Vibration Motors: étape 7, image 1 de 2 Xbox 360 Wireless Controller 3D Analog Sensor Replacement, Vibration Motors: étape 7, image 2 de 2
    • Use the flat end of a spudger to remove the vibration motor cable, moving it upward from its socket on the logic board.
    • Lift the vibration motor out of the front case.
  8. Xbox 360 Wireless Controller 3D Analog Sensor Replacement: étape 8, image 1 de 2 Xbox 360 Wireless Controller 3D Analog Sensor Replacement: étape 8, image 2 de 2
    • Remove the vibration motor from the other side of the controller using the same method previously described.
    • The left motor has significantly more counterweight than the right motor.
  9. Xbox 360 Wireless Controller 3D Analog Sensor Replacement, Logic Board: étape 9, image 1 de 2 Xbox 360 Wireless Controller 3D Analog Sensor Replacement, Logic Board: étape 9, image 2 de 2
    • Lifting from the headphone jack and power plug, remove the logic board from the front case.
  10. Xbox 360 Wireless Controller 3D Analog Sensor Replacement, Triggers: étape 10, image 1 de 3 Xbox 360 Wireless Controller 3D Analog Sensor Replacement, Triggers: étape 10, image 2 de 3 Xbox 360 Wireless Controller 3D Analog Sensor Replacement, Triggers: étape 10, image 3 de 3
    • Using your thumb and forefinger, push the left trigger toward the right side of the controller. Simultaneously push the trigger control arm in the opposite direction.
    • The trigger has a peg that fits into a slot in the trigger arm. Be sure to push far enough so that the peg clears the slot.
    • Push the trigger arm downward.
  11. Xbox 360 Wireless Controller 3D Analog Sensor Replacement: étape 11, image 1 de 3 Xbox 360 Wireless Controller 3D Analog Sensor Replacement: étape 11, image 2 de 3 Xbox 360 Wireless Controller 3D Analog Sensor Replacement: étape 11, image 3 de 3
    • Insert the edge of a spudger in between the trigger and the trigger assembly near the left edge. Pry the housing away from the catch on the trigger.
    • Using the previously described technique, pry the housing on the right edge away from the trigger.
    • Rotate the trigger away from the logic board, past its housing.
  12. Xbox 360 Wireless Controller 3D Analog Sensor Replacement: étape 12, image 1 de 3 Xbox 360 Wireless Controller 3D Analog Sensor Replacement: étape 12, image 2 de 3 Xbox 360 Wireless Controller 3D Analog Sensor Replacement: étape 12, image 3 de 3
    • Using a spudger, pry the trigger spring off its peg on the trigger housing.
    • Pull the trigger spring out of the trigger.
  13. Xbox 360 Wireless Controller 3D Analog Sensor Replacement: étape 13, image 1 de 3 Xbox 360 Wireless Controller 3D Analog Sensor Replacement: étape 13, image 2 de 3 Xbox 360 Wireless Controller 3D Analog Sensor Replacement: étape 13, image 3 de 3
    • Slide the trigger toward the right side of the logic board, and rotate it clockwise.
    • Remove the right trigger from the logic board.
    • To remove the left trigger from the logic board, follow the procedure previously described for the right trigger.
    • To remove the trigger control, only one has to be removed as it is over the analog sensor (left side).
    • Optional: It is easier to remove both, so as to avoid burning or melting the plastic while working.
    • The part should easily slide out once the solder is properly removed. If not, go back and check for solder left in the joints.
    • Heat and suck up the solder.
    • Remove analog sensor and place new part.
    • Hold part in place and make a quick solder to hold it up in place.
    • Now solder all joints and follow in reverse.
_Z_
Membre depuis le 03/18/12
9 698 Réputation
2 tutoriels rédigés
Équipe
Android Alliance Membre de l'équipe Android Alliance
Community
96 membres
757 tutoriels rédigés
1 commentaire de tutoriel
this guide will be finished as soon as i have time.
_Z_ - Réponse Partager
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 9
30 derniers jours : 54
Total : 2,998
