Introduction
Put some feeling back in your gameplay by replacing the vibrator motors in your Xbox 360 wireless controller.
Pièces
Aucune pièce spécifiée.
Depress the battery release button on the top of the controller.
Remove the battery holder from the controller.
Use a pair of tweezers to peel the barcode sticker from the battery compartment.
Insert a Spudger between the front and rear cases along the left edge of the controller.
Rotate the spudger toward the front of the controller, prying the two cases apart.
Use the flat end of a spudger to remove the vibration motor cable, moving it upward from its socket on the logic board.
Lift the vibration motor out of the front case.
17 autre(s) ont terminé cette réparation.
