Aller au contenu principal
Xbox Disassembly
Ce dont vous avez besoin
Vidéo d'introduction
  1. Xbox Disassembly, Xbox Disassembly: étape 1, image 1 de 1
    • Start with your Xbox unplugged and sitting on a flat, stable surface.
  2. Xbox Disassembly: étape 2, image 1 de 1
    • Flip the Xbox over and pry off the rubber feet with a metal spudger.
  3. Xbox Disassembly: étape 3, image 1 de 2 Xbox Disassembly: étape 3, image 2 de 2
    • Peel back both the silver sticker and the white barcode sticker to reveal two additional screws.
  4. Xbox Disassembly: étape 4, image 1 de 1
    • Use a T20 Torx screwdriver to remove the four screws located under the rubber feet you just removed as well as the two screws from beneath the stickers removed in the previous step.
  5. Xbox Disassembly: étape 5, image 1 de 2 Xbox Disassembly: étape 5, image 2 de 2
    • Once the bottom shell is no longer attached, carefully turn the Xbox right-side-up and lift off the top shell.
  6. Xbox Disassembly: étape 6, image 1 de 2 Xbox Disassembly: étape 6, image 2 de 2
    • Move the grey ribbon cable out of the way in order to remove the three 3 mm screws using T10 Torx screwdriver. They are located on the upper right corner, lower right, and lower left corners of disk drive.
    • The screw on the lower left corner of the disk drive is not in the hole that it appears to be in, but rather just closer to the corner.
  7. Xbox Disassembly: étape 7, image 1 de 2 Xbox Disassembly: étape 7, image 2 de 2
    • Lift the hard drive storage unit out of the Xbox. It should come right out.
    • Take the power cable out of the track around the hard drive so that the unit will come out easier.
  8. Xbox Disassembly: étape 8, image 1 de 3 Xbox Disassembly: étape 8, image 2 de 3 Xbox Disassembly: étape 8, image 3 de 3
    • Use a T15 Torx screwdriver to remove four 3.37mm screws from both sides of the hard drive.
    • Remove the plastic housing from the hard drive. It does have some clips on it, but it should come right off.
  9. Xbox Disassembly: étape 9, image 1 de 2 Xbox Disassembly: étape 9, image 2 de 2
    • Unplug both the ribbon cable and power cable from hard drive.
    • They are in there pretty tightly, so this may take some effort.
  10. Xbox Disassembly: étape 10, image 1 de 3 Xbox Disassembly: étape 10, image 2 de 3 Xbox Disassembly: étape 10, image 3 de 3
    • Remove the disk drive. It should come right out.
    • Unplug the ribbon cable and yellow cables from back of disk drive.
  11. Xbox Disassembly: étape 11, image 1 de 1
    • Pry back the black plastic tabs around the disk drive in order to remove it from its housing. Once removed, set the drive aside.
  12. Xbox Disassembly: étape 12, image 1 de 1
    • Unplug the multi-colored power cord from the motherboard. It can be plugged in very tight, so it may take some effort to unplug it.
  13. Xbox Disassembly: étape 13, image 1 de 2 Xbox Disassembly: étape 13, image 2 de 2
    • Using T10 Torx screwdriver, remove two 3mm screws from the power supply board.
  14. Xbox Disassembly: étape 14, image 1 de 2 Xbox Disassembly: étape 14, image 2 de 2
    • Remove the power supply and set it aside. It should lift right out.
  15. Xbox Disassembly: étape 15, image 1 de 2 Xbox Disassembly: étape 15, image 2 de 2
    • Unplug the bundle of yellow cables as well as the rainbow cord from the motherboard.
  16. Xbox Disassembly: étape 16, image 1 de 2 Xbox Disassembly: étape 16, image 2 de 2
    • Remove eleven 3mm screws from motherboard, using a T10 Torx screwdriver. Refer to the picture to find all eleven.
    • Unplug the power cable attached to the fan.
  17. Xbox Disassembly: étape 17, image 1 de 1
    • Remove the motherboard from the Xbox. As long as all of the screws are out and the fan is disconnected, it will lift out easily.
  18. Xbox Disassembly: étape 18, image 1 de 1
    • Pry the plastic fan clips away from the fan base and remove the fan.
    • This may take a little effort, as the clips are pretty stiff. Beware, the fan will be filthy.
  19. Xbox Disassembly: étape 19, image 1 de 2 Xbox Disassembly: étape 19, image 2 de 2
    • Using a T10 Torx screwdriver, remove two 3mm screws from each of two controller sockets.
    • Take the sockets out by pulling back and up at the same time.
  20. Xbox Disassembly: étape 20, image 1 de 1
    • Congratulations, your Xbox is now completely dismembered.
48 autres ont terminé cette réparation.
rmarstel
Membre depuis le 10/29/09
5 674 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 18-2, Maness Fall 2009 Membre de l'équipe Cal Poly, Team 18-2, Maness Fall 2009
CPSU-MANESS-F09S18G2
3 membres
24 tutoriels rédigés
10 commentaires
Awesomeness, thanks a lot!
godoyander - Réponse
Thanks a million - perfect!
xan_lucky16 - Réponse
Heatsink removal?
Matt Russell - Réponse
Face plate removal?
Herberth Alvarez - Réponse
Did a complete cleanup and refresh of my Xbox thanks to your guide, thank you :)
Mickaël STEMMER - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 77
7 derniers jours : 444
30 derniers jours : 1,904
Total : 181,828
