Introduction
The colour camera is used to capture visual data. It is mounted on the heat sink inside the Kinect.
Pièces
Aucune pièce spécifiée.
Remove the sticker on the underside of the device.
Remove the four 3.1x7.7 mm T9 screws underneath the sticker.
While you're at it, remove the four 3.1x23.6 mm T9 screws beneath the sticker. Make note of the sizes and locations of the screws.
Using your thumbs, press firmly against the outer case on either side of the stand. This will disengage the internal assembly.
Lift the internal assembly with the spudger.
Remove the assembly from the case. You now have access to the inner shell of the kinect, along with the heat sink, microphone, and LED sensor.
Remove the eight 2.9x7.6 mm T9 screws from the rear of the internal case.
Lift the internal metal case from the plastic shell enclosing the heat sink assembly.
Go ahead and start by removing the Colour Camera's lens cap. This way you can remove the Camera without anything in your way.
