Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Xbox One Kinect LED Sensor Replacement
Ce dont vous avez besoin
  1. Xbox One Kinect LED Sensor Replacement, Outer Shell: étape 1, image 1 de 1
    • Remove the sticker on the underside of the device.
    • Remove the four 3.1x23.5 mm T10 screws underneath the sticker.
    • While you're at it, remove the four 3.1x7.5 mm T10 screws beneath the sticker. Make note of the sizes and locations of the screws.
    Demander à FixBot
  2. Xbox One Kinect LED Sensor Replacement: étape 2, image 1 de 3 Xbox One Kinect LED Sensor Replacement: étape 2, image 2 de 3 Xbox One Kinect LED Sensor Replacement: étape 2, image 3 de 3
    • Remove the back panel.
    • Remove the black panels on either side of the Kinect, and remove the 3.1x7.5mm T10 screws underneath them.
    Demander à FixBot
  3. Xbox One Kinect LED Sensor Replacement: étape 3, image 1 de 3 Xbox One Kinect LED Sensor Replacement: étape 3, image 2 de 3 Xbox One Kinect LED Sensor Replacement: étape 3, image 3 de 3
    • Using your thumbs, press firmly against the outer case on either side of the stand. This will disengage the internal assembly.
    • Lift the internal assembly with the spudger.
    • Remove the assembly from the case. You now have access to the inner shell of the kinect, along with the heat sink, microphone, and LED sensor.
    Demander à FixBot
  4. Xbox One Kinect LED Sensor Replacement, Removing the LED Sensor: étape 4, image 1 de 3 Xbox One Kinect LED Sensor Replacement, Removing the LED Sensor: étape 4, image 2 de 3 Xbox One Kinect LED Sensor Replacement, Removing the LED Sensor: étape 4, image 3 de 3
    • Disconnect the ribbon cable between the sensor driver board and the motherboard.
    • Remove the 3.0x7.5 mm T9 screw holding the sensor driver board to the heat sink.
    • Remove the infrared sensor board for the Kinect.
    Demander à FixBot
Malak Anshassi
Membre depuis le 09/22/14
338 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 1-3, Hickman Fall 2014 Membre de l'équipe USF Tampa, Team 1-3, Hickman Fall 2014
USFT-HICKMAN-F14S1G3
4 membres
7 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 12
30 derniers jours : 67
Total : 1,491
