Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Xbox One Kinect Outer Shell Replacement
Ce dont vous avez besoin
  1. Xbox One Kinect Outer Shell Replacement, Outer Shell: étape 1, image 1 de 1
    • Remove the sticker on the underside of the device.
    • Remove the four 3.1x23.5 mm T10 screws underneath the sticker.
    • While you're at it, remove the four 3.1x7.5 mm T10 screws beneath the sticker. Make note of the sizes and locations of the screws.
  2. Xbox One Kinect Outer Shell Replacement: étape 2, image 1 de 3 Xbox One Kinect Outer Shell Replacement: étape 2, image 2 de 3 Xbox One Kinect Outer Shell Replacement: étape 2, image 3 de 3
    • Remove the back panel.
    • Remove the black panels on either side of the Kinect, and remove the 3.1x7.5mm T10 screws underneath them.
  3. Xbox One Kinect Outer Shell Replacement: étape 3, image 1 de 3 Xbox One Kinect Outer Shell Replacement: étape 3, image 2 de 3 Xbox One Kinect Outer Shell Replacement: étape 3, image 3 de 3
    • Using your thumbs, press firmly against the outer case on either side of the stand. This will disengage the internal assembly.
    • Lift the internal assembly with the spudger.
    • Remove the assembly from the case. You now have access to the inner shell of the kinect, along with the heat sink, microphone, and LED sensor.
Charles Schoonover
Membre depuis le 09/22/14
215 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 1-3, Hickman Fall 2014 Membre de l'équipe USF Tampa, Team 1-3, Hickman Fall 2014
USFT-HICKMAN-F14S1G3
4 membres
7 tutoriels rédigés
1 commentaire de tutoriel
Again, another great guide, guys. Also, this is a solid prerequisite. I noticed when reviewing this one that you did a good job of indicating which tools to use and when. Your markup is clear and concise, and your writing is not overly technical and complicated. Your photos and action steps are also very clear. You did a great job this semester!
P.S. -- I'm not sure if we're actually supposed to post our reviews as comments here. You may not want them on your guides! If I'm mistaken here, don't hesitate to remove them. I'm submitting through Canvas as well.
Noah Hickerson - Réponse Partager
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 68
Total : 2,900
