Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
If you want to replace the hard drive with one that has a larger capacity, this guide will teach you how to replace the hard drive.
Pièces
Aucune pièce spécifiée.
  1. Flip the Xbox One S so that the bottom of the case is facing upward.
    • Flip the Xbox One S so that the bottom of the case is facing upward.
  2. Insert the plastic opening tool into the  gap between the bottom of the case and the grated top side. Then find the clips in between that hold the case in place.
    • Insert the plastic opening tool into the gap between the bottom of the case and the grated top side. Then find the clips in between that hold the case in place.
    • Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
    • You will hear clicking sounds when you are prying the case open. It may be fairly difficult to remove the bottom.
    • It's possible that the clips may break when you remove the bottom from the case.
    • We recommend starting at one corner and sliding the prying tool along the edges of the Xbox One S. Once the first few clips are opened you can lift the cover up to find the remaining clips.
  3. Once all of the clips are opened, remove the bottom part of the case.
    • Once all of the clips are opened, remove the bottom part of the case.
  4. Use a T10 Torx screwdriver to remove the six green 50 mm long screws from the metal case labeled F1 through F6. Use a T10 Torx screwdriver to remove the six green 50 mm long screws from the metal case labeled F1 through F6.
    • Use a T10 Torx screwdriver to remove the six green 50 mm long screws from the metal case labeled F1 through F6.
  5. Insert an opening tool gently between the top cover and metal casing on both sides to prepare the cover for removal. This step is necessary because you need to pry interior rivets away from the exterior case. The interior rivets that hold the case in place are circled in the last image. After you gently pry in the areas demonstrated, the side panel of the exterior case will be able to come off of the rest of the casing. Look at the image in Step 7 for clarification on how the exterior case disassembles.
    • Insert an opening tool gently between the top cover and metal casing on both sides to prepare the cover for removal.
    • This step is necessary because you need to pry interior rivets away from the exterior case. The interior rivets that hold the case in place are circled in the last image. After you gently pry in the areas demonstrated, the side panel of the exterior case will be able to come off of the rest of the casing.
    • Look at the image in Step 7 for clarification on how the exterior case disassembles.
  6. Gently separate the interior case from the white exterior case using the appropriate method. Gently separate the interior case from the white exterior case using the appropriate method.
    • Gently separate the interior case from the white exterior case using the appropriate method.
  7. Flip the interior case so it is fan side upward.
    • Flip the interior case so it is fan side upward.
  8. To access the hardware within the casing, you can pop and lift the top panel of the casing. It should come right off.
    • To access the hardware within the casing, you can pop and lift the top panel of the casing. It should come right off.
  9. To replace the hard drive, flip over the console and remove the two 10 mm T-10 Torx screws, C3 and C4, from the backside of the Xbox One S. This will allow the plastic casing surrounding the hard drive to become detached from  the rest of the console.
    • To replace the hard drive, flip over the console and remove the two 10 mm T-10 Torx screws, C3 and C4, from the backside of the Xbox One S.
    • This will allow the plastic casing surrounding the hard drive to become detached from the rest of the console.
  10. Gently disconnect the hard drive from the motherboard (at the two plastic connector bodies). Gently disconnect the hard drive from the motherboard (at the two plastic connector bodies). Gently disconnect the hard drive from the motherboard (at the two plastic connector bodies).
    • Gently disconnect the hard drive from the motherboard (at the two plastic connector bodies).
7 autre(s) ont terminé cette réparation.
Victoria Law
Membre depuis le 26/04/2017
781 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team S22-G3, Livingston Spring 2017 Membre de l'équipe Cal Poly, Team S22-G3, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G3
4 membres
41 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 2
7 derniers jours : 12
30 derniers jours : 99
Total : 3,749
